| new TB
__________________ Cinquecento Sport 1.1 Last edited by PeteCunha; 27-08-2008 at 01:40. | |||
| custodian of imola blue | Re: new TB See the FAQ. A few people have used the bigger (can't remember if it's 34 or 36mm) from a Pugeot. A search should find it.
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | ||
| The following user says "Thank You!" to fingers99 for this useful post: | ||
PeteCunha (07-10-2008) | ||
| | #3 | ||
| Re: new TB ok ok TY... the original one it's 30mm???
__________________ Cinquecento Sport 1.1 | |||
| | #4 | ||
| Re: new TB not sure but i think the original one is 32mm
| The following user says "Thank You!" to nmrmak for this useful post: | ||
| | #5 | ||
| Re: new TB 30mm for the cinq sporting. 32 from the punto 60, but u need to measure, because someone has found 30mm in a punto 60. the 32mm probably the cheapest to do, and it is plug and play
__________________ Wanted : Nothing at the moment | |||
| The following user says "Thank You!" to ycming for this useful post: | ||
| | #6 | ||
| TruBlu | Re: new TB as above, but remember you need the spacer from between the TB and inlet manifold as well as diameter matches the tb, no point having a 30mm spacer with a bigger TB . If you go for a 32mm from a punto60 you can use the one from the punto. go for anything bigger and you'll need a spacer to match making up. Have a search, theres plenty on this topic.
__________________ ![]() | ||
| The following user says "Thank You!" to blu73 for this useful post: | ||
| | #7 | ||
| Re: new TB
| | #9 | ||
| I Need Beer | Re: new TB No a Punto 75 one will not fit, these are designed to be used with MPI setups and are "dry", if you compare them to your SPI one you will notice that they are missing the vital fuel injector that you need. the biggest one you can get off another car is a 36mm one from a 1.4 Peugeot/Citroen (one with webber fuel injection so not everone will fit) if you want bigger than that it is Tricker time
__________________ VAD Hi Boost Turbo Cinq None Fiats 3.2 V6 Cavalier, Peugeot 206 GTI 180 & JR Supercharged Mk2 Mazda MX5 1.8 | ||
| The following user says "Thank You!" to allanhelen for this useful post: | ||
| | #10 | ||
| Re: new TB Apparently there is something you can do with the 75, but it requires the machining of a new spacer, and matching up your original throttle body top to the bottom of the 75 TB. Simply because the the parts are nearly compatible, but as Allanhelen said, it's missing a fuel injector. I'm pretty sure that's right? Still learning all this myself heh. Luke.
__________________ Total n00b | |||
| The following user says "Thank You!" to SuicideUK for this useful post: | ||
| | #11 | |||
But it's probably not worth the effort. If short of cash, I'd go the Pug route, otherwise, contact Tricker.
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | |||
| | #12 | ||
| Scandinavian Passion.... | Re: new TB Surely you can just split the throttle body from the sensor plate and replace it with the SPI injector/sensor plate.
__________________ Daily Driver: Seicento Sporting, Dark Grey, MPI 1108cc 8v, stock externals Track Day: Seicento Sporting, Yellow, High Boost 1247cc 8v, Factory Abarth body kit Luxury Liner: Volvo V70 D5 Sport, Black, chipped & uprated intercooler, V70R body kit Last edited by StoneNewt; 31-08-2008 at 16:11. | ||
| The following user says "Thank You!" to StoneNewt for this useful post: | ||
| | #13 | ||
| Re: new TB That's what I was thinking. I think the tricker is the best, enough air going in to turn up the fuel pressure regulator and get more BHP. Atleast that's what's been shouted about on here. 40mm throttle body for £100. Luke.
| | #14 | ||
| I Need Beer | Re: new TB I am sure there was a great thread a long time ago on this ( i mean a long time at least a couple of years) but iirc it is not plug and play the nearest one is 32 mm punto 60 & 36mm PSA, I don't know the size of the the 75 tb but if it was bigger than 32mm and a direct swap it would be in use by loads of people
| | #15 | ||
| Re: new TB The 75 has a 38mm throttle body, I was enquiring about the work gone into these a while ago. Luke.
