The FIAT Forum
Old 24-08-2008   #1
Trader Rating: (0)
light gremlins
i have afew issues with my lights on my 1996 1.1 cinq sporting, i'm guessing bad earths, but they all seem to be in good condition.
when i break my n/s indicator comes on.
when indicating left they work, but when i break they become solid.
when indicating left my sidelights flash with them.
when dipped beam is on the n/s indicators become solid,
the part that gets me is the head lights and indicators are on different switches and different units.
also,my speedo cable has snapped, do i need a speedo for mot??
any help, do i need a new loom, and is it reasonably simple to change?
sicskate is offline
Old 24-08-2008   #2
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Re: light gremlins
You can never tell that the earths are OK by looking. Need to undo them, clean them up, coat with vaseline or silicon grease, do em up again. The ones under the bumper are well worth a look.
Other possibilities are wrong bulbs/wrongly fitted bulbs/corroded bulbs or contacts/failed bulbs.
Halfords have a great little glass fibre pen thing which is ideal for cleaning difficult to get at stuff.
A long afternoon with WD40, vaseline, a scotchbite pad and a glass fibre pen should see it sorted.
Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes!
fingers99 is offline
Old 26-08-2008   #3
This parrot is no more...
craigb244's Avatar
Trader Rating: (0)
craigb244 has donated!
Re: light gremlins
and more if your and iron man
++Ducati fund - £150 (needed around 2k)++
craigb244 is offline
Old 26-08-2008   #4
fingers99's Avatar
Trader Rating: (1)
Re: light gremlins
As in "made in Scotland, from girders"?
Old 27-08-2008   #5
FIREsporting's Avatar
Trader Rating: (0)
FIREsporting has donated! United Kingdom
Re: light gremlins
A Hot long afternoon with WD40 vaseline
FIREsporting is offline
Old 27-08-2008   #6
Trader Rating: (0)
Yugoslavia
Re: light gremlins
exactly what i thought... a hot long afternoon with vaseline... Need to undo them, clean them up, coat with vaseline or silicon grease, do em up again.
nmrmak is offline
Old 27-08-2008   #7
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: light gremlins
I don't think this has got anything to do with a car!!
PD
rallycinq is offline
Old 27-08-2008   #8
TruBlu
blu73's Avatar
Trader Rating: (0)
blu73 has donated! United Kingdom
Re: light gremlins
Shouldn't need to, mum's punto went through 2 MOT's without the speedo working. Tacho must work if theres is one but apparently the speedo doesn't. Seems a bit wierd to me but thats the rule.
Obvioulsy though, speedo is quite handy so would get new one, won't be expensive
blu73 is offline
Old 29-08-2008   #9
Trader Rating: (0)
Re: light gremlins
cheers everyone,
got the speedo working, it had come lose on the gearbox.
also, which earths are under the bumper (front or back and where?)
sicskate is offline
Old 29-08-2008   #10
fingers99's Avatar
Trader Rating: (1)
Re: light gremlins
Earths for the rear lights. Under the back bumper. There are also more obvious earths in the engine bay.
Old 31-08-2008   #11
Trader Rating: (0)
Re: light gremlins
ok, i spent about 3hours trying 2 sort this today but still no luck.
i cleaned the contact points and put vaseline on them, i did every earth i could see but still no luck.
should i just change the loom over as mine has had a crappy alarm installed and i'm unsure whats what now.
sicskate is offline
Old 31-08-2008   #12
fingers99's Avatar
Trader Rating: (1)
Re: light gremlins
It could be the alarm that's causing the problem. Or crappy fitting.
Swapping the loom is one way to go, quite a bit of work, though, another might be popping into an auto-electrician.
Old 31-08-2008   #13
rallycinq's Avatar
Trader Rating: (1)
Re: light gremlins
Did you clean the connections on the rear light clusters and the earths under the back bumper?
Still sounds like an earth problem to me.
PD
Old 01-09-2008   #14
Trader Rating: (0)
Re: light gremlins
yeah i did all the points i could find including the one behind the bumper.
the ns lights are ok now but the o/s r still bad.
could i just solder new earths to each light?
sicskate is offline
Old 01-09-2008   #15
Trader Rating: (0)
Re: light gremlins
my brothers a sparky so i'll ask him too have a look, otherwise i will get someone 2 have a look.
sicskate is offline
(G) Electrical gremlins lanciaman Marea 11 26-09-2008 10:08
Gremlins... craigsh Ulysse 2 04-08-2008 11:38
gremlins???? smiggypitbull Tipo 0 29-04-2008 20:57
(G) Various electrical Gremlins......... phil.1380 Stilo 18 17-03-2008 10:58
(T) Electrical gremlins AIJ29 Cinquecento / Seicento 3 09-03-2005 22:50
