The FIAT Forum
Old 02-07-2008   #1
Bring On The Trumpets!
ronnieronson's Avatar
Trader Rating: (0)
ronnieronson has donated! United Kingdom
Question MPI lambda sensor
Anyone know off hand what the part number is for the front (pre-cat) lambda is, or where I can get one cheap?
Also anyone know of lambdas from other engines which might be suitable?
ronnieronson is offline
Old 02-07-2008   #2
Rip'n'Burn
Smiler121's Avatar
Trader Rating: (1)
Smiler121 has donated! United Kingdom
Post Re: MPI lambda sensor
I saved quite a few quid swapping both Lambdas (changed one & it turned out to be the other that was dead) by buying cheaply listed Alpha Romeo Lambdas for about £15 then cutting the wire & re-fitting the plastic plug from my existing Lambda.
Many Lambdas share the same sensor but they use longer leads & all have plugs with a plastic notch sticking out in different places, which stops them from fitting over your connector. As long as you wire the proper Cento plug on correctly (only 4 wires) you'll be fine.
www.ngk.co.uk gives a selector that also helps explain things & to know which OEM sensor you want.
Take a look at http://cgi.ebay.co.uk/Lambda-O2-Sens...742.m153.l1262 (Ebay item 370062893446) sold by airflowmeter, gives a few suggestions.
That which does not kill us makes us stronger!!!
Smiler121 is offline
The following user says "Thank You!" to Smiler121 for this useful post:
ronnieronson (02-07-2008)
Old 02-07-2008   #3
kritip's Avatar
Trader Rating: (3)
kritip has donated! United Kingdom
I've got a pre cat in my bag of bits you can have for P+P (not a for sale thread )
It was working when it was removed.
I also have the post car, but the wired have been cut on that one.
You get that compression test done?
Kristian
Black Seicento Sporting mk2
1242cc 16V conversion finished and removed!
Megasquirt installed, a constant evolution
1368cc and 6 speed running great now
My Members Motors thread
kritip is online now
The following user says "Thank You!" to kritip for this useful post:
Old 02-07-2008   #4
Trader Rating: (0)
That's a great find mate - thanks
Thinking I might get a pair of universal ones - they come with heat shrink, and can't possibly be any worse than my faulty ones
Got quoted by Andrew Page for £72 ex vat!!! for a genuine one, and begrudge paying so much
Old 02-07-2008   #5
Trader Rating: (0)
Kristian
perfect!
you are a legend!
- PM on it's way!
not got the compression test done yet, but have bought a tester - not got a day off for another 5 days, but will try and get that sorted asap.
Ran the car with pre-cat lambda unplugged, and absolutely nothing changed!, so I can only assume that it's fubar!
Unplugged the post cat lambda, and that made the ecu spaz out - so pretty sure that one's ok for now
Old 03-07-2008   #6
Trader Rating: (2)
ycming has donated! United Kingdom
Those universal one .. is utter rubbish ... used them before no good .
In my experienece they last around 1 year .. sometime less
Ming
Wanted : Nothing at the moment
ycming is offline
Old 03-07-2008   #7
Rip'n'Burn
Smiler121's Avatar
Trader Rating: (1)
Cool Re: MPI lambda sensor
Kristian
I'd have Kristian's post cat off him too if I were you & re-use the plug off your knackered one on that.
ycming - I've read that the Universal ones aren't great quality myself.
Old 03-07-2008   #8
JR
Trader Rating: (0)
Italy
Yes I personally think you are better sticking with OE ones. Even if they are second hand.
I briefly had an aftermarket one off a friend brand new who gave it to me for nothing and it started losing fuelling response after around 6 months.
I then ordered two new OE ones and has been perfect since and fuelling well.
Alfa Romeo 147 GTA
Fiat Seicento 16v
JR is offline
Old 05-07-2008   #9
Trader Rating: (0)
Talking Re: MPI lambda sensor
Well, thanks to the legend that is Kristian - a mysterious parcel turned up for me today... containing Lambda sensors! Woooo!
Was an absolute total cock of a job it was!
Foolishly I had my 1st attempt almost immediately after driving home from work - and I am now the unfortunate wearer of some weird little burns on my right wrist, from trying to get my hand behind the heat shield.
an hour later I took the bolts off the heat shield, and manouvered it down enough to get a 7/8ths spanner in there and undo the nut (which came off suprisingly easily!).
New lambda went in, tightened everything back up & last but not least - reset the ecu.
Test drive results:
Car still idles a little roughly - but now it's equally cold or hot.
Fan doesn't seem to cut in quite as much - which is nice.
Idle rpm is no longer erratic or on the verge of stalling - at a guess i'd say 800-850 rpm - cold or hot.
I'm guessing there is still something at fault somewhere - so it's back to the list (cheifly replace the coils and do a compression test), but at least she feels safer to drive again
I cannot express just how thankful I am to FiatForum - but specifically Kristian - absolute Legend!
Old 08-07-2008   #10
Panda's with Gadget's
Most Easterly Pandas's Avatar
Trader Rating: (0)
Most Easterly Pandas has donated! Bolivia
The only other Fiat that the Sei shares it's Lambda with is the Panda. From what I remember when looking for part number for my Panda, it listed it as being compatable for both
Jon.
Most Easterly Panda's - Panda'ing in East Anglia
5 Panda's! 1989 F-reg 750L, 1991/1992 (not sure as on a NI plate) Panda 1000CL,
1993 K-reg Selecta (1108cc) x2! 1988 E-reg Sisley 4x4
Originally Posted by purple haze View Post
Just did not push my buttons...although when i pushed its buttons they all worked!!
If my post or someone else's has helped, say thank you using the Thanks Button \/
Most Easterly Pandas is offline
Old 08-07-2008   #11
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
AppleSei has donated! United Kingdom
i am assuming that is only for SPI sei though and not MPI which is needed here, in which case the panda one will be useless??
2001 Modded Sei Sporting - GONE!!
1998 Ford Mondeo 1.8LX - P/X'ed
2002 02 Ford Focus 1.6 Zetec w/ Climate Pack!
AppleSei is offline
Old 08-07-2008   #12
Rip'n'Burn
Smiler121's Avatar
Trader Rating: (1)
I'd like to know (but I'm not bothered enough to look it up) if there is actually any difference in the sensor used in the Mpi vs Spi - when you take a look an the link I posted earlier it really does appear that a large amount of sensors are the same but the lead length & connector type are different.
Old 10-07-2008   #13
Trader Rating: (0)
well after a bit of rewiring, and lots of oil on the old nut, I managed to get the post cat one swapped.
Fuel economy seems better (though i wont know until ive done a full tanks worth of driving)- and the idle is holding quite well at approx 800 rpm.
Next job of course is to do a compression test, and double check all my hoses... But that said im much much happier with the way she runs :-)
Old 17-07-2008   #14
Trader Rating: (0)
Well, a week on, and shes done nearly 190 miles on 3/4 of a tank, which has consisted of 95% "spirited" town driving.
Compared to the previous 180 miles per tank I'm well happy - starting to see the kind of fuel economy I came to love from Bertie.... damn I miss that car...
Idle is still a little iffy - feels like a missfire every 10 seconds or so.
To make sure its not igintion related, I've administered another new set of leads, plugs and a fresh set of coils - but this seems to have helped very little.
Still to do a compression test (I know - should have done this with the coils and plugs out, but sorta forgot and was pushed for time this morning), and I'm still none the wiser about what hoses to check, and infact how to check them
(T) lambda sensor dirk70 Stilo 7 07-04-2008 22:22
(T) I got my lambda sensor done! reaper1988 Bravo / Brava 7 30-05-2007 09:45
(T) lambda sensor or....? ptre Cinquecento / Seicento 2 12-11-2003 19:22
