The FIAT Forum
Old 27-06-2008   #1
jimp's Avatar
Trader Rating: (0)
seicento wiring through bulkhead!!
Hiya!
How do I get from the cabin to the engine bay with wiring??
After 10 minutes with my feet on the parcelshelf and my head jammed under the dash, I cannot find the engine harness coming through from the engine bay.
Having removed the dash vents/speakers and heater controls I'm non the wiser; should I run it out of the window and tape it down the side of the car?!
What's the secret?
jimp is offline
Old 27-06-2008   #2
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: seicento wiring through bulkhead!!
Originally Posted by jimp View Post
What's the secret?
It was originally designed for left hand drive.
PD
rallycinq is offline
Old 27-06-2008   #3
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Pretty much sums it up!
There are two "outs" IIRC, one below the battery tray, one on the passenger side near the servo/clutch quadrant cover. Both need the carpet removing (partially).
Both are tight and difficult to find. A welding rod with some vaseline on it is useful.
Or drill a hole and use a grommet................
Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes!
fingers99 is offline
Old 27-06-2008   #4
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
this is behind the battery on a Cinq;
as has been said, the loom passes through at the other side of the car.
if you want to drill the bulkhead to run wires through, this is a good place;
arc is offline
Old 27-06-2008   #5
jimp's Avatar
Trader Rating: (0)
Thankyou arc
Thankyou fingers- you guys are a resource!!
I didn't realise the access was that low down- I'll have a look tonight...
JimP
jimp is offline
Old 27-06-2008   #6
Conway's Avatar
Trader Rating: (0)
I ran mine down the passenger side of the car and then up behind the speaker and through a grommit which is just below the the ecu sits.
Uses a old coat hanger to pull the power cables through
Conway is offline
Old 27-06-2008   #7
rallycinq's Avatar
Trader Rating: (1)
Undo the bulkhead carpet under the bonnet at the passenger side. You will see a gromet where cables come through. There is usually space for more cables there.
PD
Old 27-06-2008   #8
jimp's Avatar
Trader Rating: (0)
Thanks Conway
Thanks Rallycinq!
That's seems logical enough- I'll start from the engine side- you can't see a thing for the soundproofing internally...
I couldn't see that grommit internally, but I did see an unused one next to the wiper motor from the engine side... It's so ironic; I thought this would be the easy bit! On a larger car it would be easier I suppose...
JimP
jimp is offline
(G) Seicento speaker wiring simcox1 Cinquecento / Seicento 6 13-03-2008 01:58
seicento wiring advice please neill70 I.C.E 2 08-01-2007 19:43
(T) Seicento (02) wiring diagram bundy Cinquecento / Seicento 4 07-04-2005 10:39
(T) Seicento Wiring fault paul Cinquecento / Seicento 1 06-10-2003 05:34
