| ive got a r reg sporting its seriously lacking power wont rev over 4k wen driving top speed 40mph ive checked the timiming on original timing marks still no power ![]() please help me as loosing temper cant wait for a suggestion of wat it mite be many thanks in advance
| custodian of imola blue | Re: cinquecento sporting HELP!!!!!!!!!! Any other symptoms? Does the ECU light come on while driving? Black smoke out the back?
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | ||
| | #3 | ||
| Re: cinquecento sporting HELP!!!!!!!!!! no every thing is fine which is y im so stressy bout it i just replaced the hg because of this prob but the same. could it be carb related?.i was told it was timing but timed on original marks its the same.new leads new plugs hg the only thing i can think is fuel starvation it will rev to 6k sat still then drive it 4k ![]() ![]() ![]() ![]() ![]() ![]()
| | #4 | ||
| Ah. Not good... | Re: cinquecento sporting HELP!!!!!!!!!! Does it idle OK? | ||
| | #5 | ||
| Re: cinquecento sporting HELP!!!!!!!!!! perfect just wont drive under load
| | #7 | ||
| custodian of imola blue | Re: cinquecento sporting HELP!!!!!!!!!! Diagnosis probably makes more sense than dashing around changing stuff. Get a compression test done, wet and dry. If you pay £20 to ClubCento you get access to Rallycinqs nominal values for all the sensors (so you can test them with a multimeter) (and cheaper parts from Fluffy the Impaler). Really, it could be anything from a failed throttle position sensor to a temperature sensor to a collapsed cat or exhaust or even a clogged fuel filter.
| | #8 | |||
| | #9 | ||
| Re: cinquecento sporting HELP!!!!!!!!!! it was like it before i done the hg thats why i did it.as for if it does it cold its a permanent thing i checked for piston slap wen the head was off and it was fine.(minor movement)i cant hear any signs of a vacuum leak.i dont have a fiat garage near me (bristol)that i no of.i cant help but think fuel starvation
| | #10 | ||
| custodian of imola blue | Re: cinquecento sporting HELP!!!!!!!!!! Replacing the fuel filter is cheap and should be part of routine maintenance anyway. Use a clamp each end (proper clamp or G clamp or Mole grips with lots of protection over the jaws). Put it on the right way round! Otherwise, you really can't hear, let alone feel, piston slap on most 4 stroke engines unless the engine is a gonner. Do a compression test. Wet and dry. The tester will cost you less than paying a garage to do it. How long has it been doing this?
| | #11 | ||
| Re: cinquecento sporting HELP!!!!!!!!!! the day before i bought the car.i bought it off a friend who just passed his test but it started doing it the day he passed.ive had it a week. its pumping fuel from the pipe fine so i dont think its a fuel filter problem.but both me and me bro are mechanics n we both agreed that the rings wer fine theres compression wen you turn the engine over by hand.wen running theres no smoke it just holds back all the time wen driving.it idles perfect at 900 no hiccups no nothing ![]() ![]()
| | #12 | ||
| Re: cinquecento sporting HELP!!!!!!!!!! its only done 74395k
| | #13 | ||
| mad bad and very very old | Re: cinquecento sporting HELP!!!!!!!!!!
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #14 | ||
| custodian of imola blue | Re: cinquecento sporting HELP!!!!!!!!!! If you're mechanics, you have a compression tester. Just do it. Even a bicycle pump will show compression if you stick a finger over the end. Could well be a valve issue. Likewise, the fuel pump will pump fuel through the filter unless it's completely blocked. I give up. I've told you what to do, told you how to save money. I have no miracles left in my pocket!
| | #15 | ||
| cinq sporting | Re: cinquecento sporting HELP!!!!!!!!!! hi mate. sounds like the crank sensor. i had the same problem it reved u to 4k then spluterd. you can get 1 from your lokal scrapy 4 about a fiva its oly 1 10mm bolt to take of.
__________________ 4 sale 5mm wheel spacers. 13 road rally tyres. http://www.fiatforum.com/classifieds...0&ppuser=38877 | ||
| Tags |
| help |
