The FIAT Forum
Old 30-07-2004   #1
Trader Rating: (0)
Sodding Fan will not work!
[Right rant mode starting now..]
How it all started, back in Dec 2003 I was stuck in traffic, yippee, cooling system heated up, fan kicked in and the car overheated. At the weekend after this happened I had to replace the fan and the "motor" failed and rusted away. So Brought another one from the scrap it works as I've tested it with a fused feed from the battery.
Right, all is okay - not. For some reason, I get to overheat the car and the fan will not kick in. Pull the plug out of the rad (899 cc, green connecter in the rad) and bypassed this with a paperclip - nothing, fan will not work. Check fuse (from drivers side fuse box) with multimeter and fuse is okay. Striped side plastic to check power supply. reading is 0v with the bypass paperclip or plugged back into the rad. So the power is not getting there.
What am I doing wrong? Is there something else i've missed???? Is there another switch or fuse gone bust?
(Note, I have seen something behind the battery that say 30amp and a fan shape on it - is this another fuse for the fan, but I can't access it.)
HELP!!!!
[end rant]
Mike
Shopping List:
-40mm Lowing Springs
Cadamuro Rear Spoiler
Window Tints
Scrapped 1.2 Punto
Sei-Mad is offline
Old 30-07-2004   #2
Trader Rating: (0)
Note, where is the thermostat on a 899cc engine??? This is the only thing I've not tested?
If this is shot - is it a cheap thing from fiat or halfords?
Shopping List:
Window Tints
Scrapped 1.2 Punto
Sei-Mad is offline
Old 30-07-2004   #3
Cento Boy
surfin_fella's Avatar
Trader Rating: (0)
surfin_fella has donated! Australia
the fan is plugged in, right??
Sie
Black 96P Cinq Sporting
OMP Strut Brace, Apex -40mm kit, GSR F1i Induction, Pioneer ICE
Union JackassYou were the best thing that I ever had, and I want it back
surfin_fella is offline
Old 30-07-2004   #4
Trader Rating: (0)
oh yes. But no power from the connecter when the engine is running and the sensor bypass with a paperclip.
Shopping List:
Window Tints
Scrapped 1.2 Punto
Sei-Mad is offline
Old 30-07-2004   #5
Trader Rating: (0)
hay mate u aint the only one my fan aint working either. ive got sum1 lookin at it sat mornin.
ive already flushed the system and brought a new switch and dat wasnt worked. i fink it might b the thermostat. let us know how u get on.
Cinq Sporting - BROOM YELLOW
Abarth Front Bumper meshed,Light brows,Rear Lenses,De-Badged,Centre 4inch Exhault,3rd Brake Light,Sparco Mud Flaps,Yellow Sun Strip, K&N,Red Led washer Jet,Abarth Red Centre caps,Under Dash Red Neons,Yellow Interior,Sony Xpload Headunit & 6x9's
Lewis is offline
Old 30-07-2004   #6
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Put another live feed in straight off the attery, fuse it of course.
cheers
D
Grumpy old git going fast downhill rather than downhill fast!!
rallycinq is offline
Old 30-07-2004   #7
Trader Rating: (0)
Don't know if this is the themostat, but on one of the hoses from the rad to the engine block, there is a bolt on the bulkhead with a electonic plug coming out of it. It does look to be a switch or somesort? However the plug was lose - the metal clamp was half on/off and plug can wobble out. Took the plug out and looked into the pins - one of the pins was pushed right in so no electical contact. Pulled it back out again and now going to see if this has sorted the problem out.
I still believe this has all happened since the last "garage" service that it had[:(!] - also 1 week after the "service" backbox rusted away on one of the joints, brake cable snaps (too tight), and maps sensor pipe "falls" off.
Shopping List:
Window Tints
Scrapped 1.2 Punto
Sei-Mad is offline
Old 30-07-2004   #8
Trader Rating: (0)
bloody hell problem after problem!yeh dats the switch. i brought a new one of thos. well hopefuly i can find out my problem 2moro. il let u know how i get on.
Lewis is offline
Old 30-07-2004   #9
Trader Rating: (0)
Now, I hope it works :) - will test it tomorrow.
Shopping List:
Window Tints
Scrapped 1.2 Punto
Sei-Mad is offline
Old 31-07-2004   #10
Moderation in Moderation
GhostWKD's Avatar
Trader Rating: (0)
GhostWKD has donated! United Kingdom
failing that, check the earthing
Abarth Kitted Cinq Sporting, Sig coming soon ;)
GhostWKD is offline
Old 31-07-2004   #11
Trader Rating: (0)
good point, where is the earthing for this system?
Mike
Shopping List:
Window Tints
Scrapped 1.2 Punto
Sei-Mad is offline
Old 03-08-2004   #12
Posts: 18:
Trader Rating: (0)
Angry Re: Sodding Fan will not work!
well i got a new coolin fan sat put it on pluged it in and still it doesnt kick in and start up. i fink it might b somefink wrong wiv wire or electrics.
wot do i do now?
the fings ive done already r new radiator switch,flushed it,checked fuse.
Southey is offline
Old 05-09-2004   #13
Trader Rating: (0)
Sei-Mad is offline
work + nice weather + going out = me dead! arc Leisure Lounge 32 02-08-2004 03:30
Cheaper petrol? Will it work? bazd123 Leisure Lounge 3 26-05-2004 23:49
TMC won't work in UK poggy Ulysse 3 31-01-2004 23:31
(T) dash instrumentation doesn't work sonic Punto 6 26-01-2004 07:47
22nd January London After Work Drinks Dee Events 0 15-01-2004 05:39
