| Tamed yellow beast | intake air temp sensor????? hi anyone got any idea where abouts i can find the air intake temp sensor on my 2001 seicento sproting? photos and diagrams would help. thanks. .oli.
| Get a wriggle on! | Re: intake air temp sensor????? if its SPI then look at the link, its item 3 on the diagram/list http://www.fiatforum.com/cinquecento...-pipes-go.html
__________________ | ||
| | #3 | ||
| custodian of imola blue | Re: intake air temp sensor????? Or, if MPI, it's the 4 pin sensor on the plastic plenum chamber (combined with the MAP sensor).
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | ||
| The following user says "Thank You!" to fingers99 for this useful post: | ||
ronnieronson (17-05-2008) | ||
| | #5 | ||
| ' | Re: intake air temp sensor????? You knew that Been mentioned about 2-3 times in your threads now lolGot a pic of the 2 pin sensor? Can't remember what was there now, this it may be the soleniod for the charcoal cannister? Kristian
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() | ||
| | #6 | |||
| Bring On The Trumpets! | Re: intake air temp sensor?????
...forgive my innocence - but what's a charcoal canister when it's at home? ![]() ![]() ![]() Connects to the block via a hole held in with a c clip, and on the other side a blue pipe hooks up to it on that long shaft, and stays put with the help of some green button thing that you squeeze to remove it....
__________________ ![]() | |||
| | #7 | ||
| | #8 | ||
| this is where i stand | Re: intake air temp sensor?????
| | #10 | ||
| ' | Re: intake air temp sensor????? I was right ![]() That is the solenoid (ie switch) that controls air from the charcoal cannister. TO stop hydrocarbons leaking into the atmosphere, the furel tank is sealed (unlike on older cars). The fumes gather at teh top of the tank. A the top of the tank there is a hose that travel all the way to the wheel arch lineer. In there is a charcoal cannister. Which is simply that. A box with charcoal in it, and inlet and an outlet. The inlet to the cannister comes from the tank, the outlet goes to the solenoid, and then to the air intake. The solenoid is switched on and off, and the manifold pressure draws gas through the cannister, form the tank, under ceratin ECU conditions. This is then burnt off, as it is combusted. Thak help you? ![]() Cheers, Kristian PS. It's on all the mpi
| | roboticgimp | Stilo | 6 | 20-05-2008 14:02 |
| air inlet temp sensor? | Carlucci | Newbie Central | 2 | 07-03-2008 10:37 |
| | jimbob4212 | Cinquecento / Seicento | 8 | 23-05-2007 20:40 |
| | Forest4ever28 | Cinquecento / Seicento | 9 | 25-03-2007 08:15 |
| | nogin | Cinquecento / Seicento | 3 | 07-11-2006 16:18 |
