| Clutch Pedal Hi again. Another problem guys. The clutch pedal is very wobbly. It doesnt stay straight like the brake pedal for example. My VRT test is soon and I need to fix this problem before I take it. Any suggestions of how to make not wobble anymore? Thanks.
| custodian of imola blue | Re: Clutch Pedal Smaller font, please! Take a look, but I think where the clutch pivots, right deep down in the footwell, is a nylon bush. Replace that and all your problems should go away.
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | ||
| | #3 | ||
| yer sound like the bush fingers99
| | #4 | ||
| Re: Clutch Pedal You are right guys. The bushes. Now can you please tell me the procedure of how to replace these bushes? ![]() It seems a bit complicated...! Thanks.
| | #5 | ||
| custodian of imola blue | Re: Clutch Pedal Here's a picture. ![]() I've never had to do it, but I think you disconnect the clutch and throttle at the pedals, remove the bolt (arrowed red) remove the pedal(s) and replace the bushes. FIAT dealer for bushes or, failing that, any little engineering place will make you some up in an engineering plastic (nylon, PTFE, etc.) or a suitable bronze alloy.
| | mentalkim | Cinquecento / Seicento | 3 | 06-07-2007 01:29 |
| | sc4rf4ce | Punto | 6 | 17-06-2007 13:45 |
| | The younger modder | Cinquecento / Seicento | 2 | 22-03-2004 04:43 |
| | stiloactive | Stilo | 8 | 21-03-2004 08:17 |
