The FIAT Forum
Old 09-05-2008   #1
mrcinquecento's Avatar
Trader Rating: (0)
revs
my new seis clutch is a bit on the brutal side at the best of times, so i hope this isn't yet another problem developing, so here goes. How many revs does your seis pull at about 30mph in third? mines is currently at about 3200rpm in third, roughly 2000 in 4th, is that about right?
i don't remember my cinq being that high, but do seis have shorter gearing to compensate for their extra weight?
mrcinquecento is offline
Old 09-05-2008   #2
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Re: revs
Gearing is the same, Sporting for Sporting. The Sei MPI Sporting Abarth has lower gearing to compensate for 14" wheels, the MPI S and SX 1108 have slightly higher gearing.
By "brutal" I guess you mean your clutch is engaging right at the top of the pedal? Adjust it by turning the adjuster clockwise.
Your clutch is unlikely to be slipping -- usually this reveals itself by a perios during which the revs rise (as it were) by themselves when accelerating (it will do it around peak torque) and then settle down again.
Can't remember what revs I'm pulling at 30 in intermediate gears.
Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes!
fingers99 is offline
Old 10-05-2008   #3
Trader Rating: (0)
Re: revs
the clutch bites very quickly, no matter how smoothly you try to engage it, its a bit rough and stiff when the pedals coming up. possibly just one of the pivots?
the weight of the pedals fine, theres no crunching into reverse or first, the biting point is fairly low, but not stupidly low
Old 10-05-2008   #4
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: revs
Could be damaged springs in the driven plate. If it gets much worse its new clutch time.
Edit:- Unless someone has fitted an unsprung clutch, any history with the car?
D
rallycinq is offline
Old 10-05-2008   #5
Trader Rating: (0)
Re: revs
very little, no history on the clutch at all it's very tricky to drive smoothly, but if you are very careful, it can be driven normally... funnily enough, it seems to get a good bit better once the cars warmed up, still not perfect though
Old 10-05-2008   #6
fingers99's Avatar
Trader Rating: (1)
Re: revs
I wonder......... contaminated clutch plates?
Old 10-05-2008   #7
rallycinq's Avatar
Trader Rating: (1)
Re: revs
If the OP can live with it, fair enough, but you and I know its a clutch job.
D
Old 10-05-2008   #8
Trader Rating: (0)
Re: revs
i've had enough cento clutch problems on my cinqs to last me a lifetime and a half!... i suppose it only right if i have a sei, it too should have clutch issues
Old 10-05-2008   #9
rallycinq's Avatar
Trader Rating: (1)
Re: revs
I am guessing that you don't wish to know that having owned 5 Cinqs over 12 years I have only snapped one clutch cable and had no other problems!!
D
Old 10-05-2008   #10
Trader Rating: (0)
Re: revs
lucky you! my last cinqs clutch cable snapped 4 times in 7 months!, yes the clutch release was nackered, but i never had the funds to replace it, so just kept replacing the cable
(T) revs punto team Punto 6 09-02-2008 18:53
(G) revs needspeed Cinquecento / Seicento 4 19-12-2007 20:48
(T) Revs from no where? help! puntoadam Punto 0 29-11-2006 11:34
(T) Up and down revs/extremely high revs!! BURNER Punto 5 31-01-2005 20:39
(T) Help Revs pokerface Cinquecento / Seicento 0 21-03-2004 03:47
