The FIAT Forum
Old 24-04-2008   #1
mrcinquecento's Avatar
Trader Rating: (0)
brakes
what would be a good upgrade? disc pad and maybe caliper wise?
for the back whats the best choice? would it be easy to change to a disc set up, like with standard sei front discs at the back and bigger punto gt set up (calipers discs and pads) at the front? or would that damage the bias too much?, i've done brakes before, but never a drum to disc conversion
the brakes are shocking at the moment
mrcinquecento is offline
Old 24-04-2008   #2
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: brakes
The brakes should not be shocking. Unless you have a highly modified car then the standard brakes are more than adequate for bringing the car to a stop.
Use the search function if you want to learn about rear discs.
D
rallycinq is offline
Old 24-04-2008   #3
Trader Rating: (0)
Re: brakes
at the moment, its totally unmodified, and they really struggle to bring it to a halt, so much so i cant drive down hills at more than 10mph, because the braking's so hard to judge, i will be modding it very lightly, i won't be adding anything silly, the're will only be about 8- 10bhp added i guess, and no weight will be added, but i found the standard set up was poor on my old cinq, i want a more than adequate set up for once on the sei
i might just replace the pads and discs for new standard ones, see how it goes
Old 24-04-2008   #4
rallycinq's Avatar
Trader Rating: (1)
Re: brakes
Also check and adjust the rears. If they are wildly out then the fronts won't work properly either.
Then change the fluid if it hasn't been done in the last 24 months.
D
Old 24-04-2008   #5
Trader Rating: (0)
Re: brakes
cheers, i just got the car 3 days ago with little or no history, i have no idea when the fluid was last changed, so its a great plan to get that done too
i know the rears are badly out, so i will get all that adjusted some time this weekend, and i might actually have a handbrake when its done!
i've decided to stick with the drums at the rear for now, i will stick to as standard a set up as i can, perhaps just with some better discs or pads later on
Old 24-04-2008   #6
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Re: brakes
as rallycinq says, properly maintained the stock set up is adequate.
The easiest upgrade is fitting Punto GT disks and calipers to the front, but you need 14" wheels to do that (and decent tyres help). Personally I regard the rear disk conversion as more cosmetic than functional.
Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes!
fingers99 is offline
Old 24-04-2008   #7
Trader Rating: (2)
ycming has donated! United Kingdom
Re: brakes
hmm it is functional, in terms of renewing rear brake pads and disc, is easier than servicing the elbow and changing the shoe.
Wanted : Nothing at the moment
ycming is offline
Old 24-04-2008   #8
fingers99's Avatar
Trader Rating: (1)
Re: brakes
Given both are in good condition, there's little in it. The rear calipers, and the handbrake mechanism, have been known to seize. Indeed, this is a well known "feature" of disk as handbrake set ups.
Even were that not true, it's an expensive way of avoiding routine maintenance!
Old 24-04-2008   #9
watchyourbaK's Avatar
Trader Rating: (0)
Re: brakes
Hi
Not meaning to thread hijack but i have just ordered a set of Mintex disks and pads for me little seicento 899cc. Just wondering if anybody has had any personal experience with these Disks and Pads..
Many thanks
Rory
watchyourbaK is offline
Old 24-04-2008   #10
fingers99's Avatar
Trader Rating: (1)
Re: brakes
They'll be fine. Just put 'em on.
Old 24-04-2008   #11
I Need Beer
allanhelen's Avatar
Trader Rating: (0)
allanhelen has donated! United Kingdom
Re: brakes
errr...... sorry but of going down hill at more than 10 mph is a worry i sugest you don't drive the fuc*ing thing
you either have seized callipers or a buggered master cylinder never mind fluid or adjustment
If you have an accident as a result you would be bang to rights and if there was any doubt on this i would grass on you
don't drive it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
start with the front calipers and then master cylinder, to examine them properly you need to change the fluid anyway.
VAD Hi Boost Turbo Cinq
None Fiats 3.2 V6 Cavalier, Peugeot 206 GTI 180 & JR Supercharged Mk2 Mazda MX5 1.8
allanhelen is offline
Old 24-04-2008   #12
Trader Rating: (2)
Re: brakes
Hmm .. i think putting on those rear shoe springs will be harder then just fitting bdisc and pads..
Just my opinions tho
Ming
ycming is offline
Old 24-04-2008   #13
rallycinq's Avatar
Trader Rating: (1)
Re: brakes
Originally Posted by watchyourbaK View Post
Hi
Many thanks
Rory
I use Mintex pads al round. Thems great.
D
Old 24-04-2008   #14
fingers99's Avatar
Trader Rating: (1)
Re: brakes
Ming
But you can buy a tool to put on the springs for less than a tenner. The caliper mounts alone will cost a lot more than that to have made up. It's not a bolt on conversion by any means.
Old 24-04-2008   #15
I Need Beer
allanhelen's Avatar
Trader Rating: (0)
Re: brakes
guys!!!! this bloke car doesn't stop! if you can't go down hill without thinking you won't stop then this is a front brake issue regardless of a rear disk conversion or not.
I have one car with rear disc's and one without and TBO i prefer the drum set up, (but my rear calipers are not 100%, 21% efficency on MOT so most of the braking is on the front) so if my turbo can stop with 21% rear efficency quicker than most cars i would still say look at the front brakes mate
Tags
brakes
(T) Brakes EX07 Grande Punto 6 04-07-2007 17:02
(T) Brakes again Drinu Uno 2 26-12-2006 16:05
brakes boyjoe13 Newbie Central 4 30-04-2006 21:24
(T) Brakes bluestorm Bravo / Brava 3 17-01-2005 15:44
Noisy brakes / squeeking brakes on Tipo gfitega Tipo 2 09-10-2004 11:58
