The FIAT Forum
Old 18-07-2004   #1
Trader Rating: (0)
Turning over but not firing?
I bought myself a lil fiat cinquecento 899CC a few months ago and until now has really been running well. However, over the last few weeks the little car has become desicively dodgy when starting. The car seems to turnover well, however doesnt seem 2 fire, causing the car not 2 start.
I have changed the spark plugs, and several differenty ideas, however now a light to the side of the battery on the dashboard is showing up, althought i dont have the handbook.
Does anyone reckon that it could be a problem with the fuel injection system, as when it fires, she runs really well?
Reply a.s.a.p. thanx!
jclayton
JClayton is offline
Old 18-07-2004   #2
Trader Rating: (0)
if your car won't start and the starter motor doesn't turn
1. Open the bonnet and make sure the battery terminals are clean and tight.
2. Switch on the headlights and try to start the engine. If the headlights go very dim when your trying to start, the battery is probably flat.Get out of trouble by jumping the car using a mates car. Run for an hour with out turning of, by this i mean drive the car for an hour.
If your car won't start even though the starter motor turns as normal
1. Is there fuel in the tank?
2. Is there moisture on any of the electircal components under the bonnet? Switch off the ignition, then wipe out any obvious moisture with a dry cloth. Spray a water reppellent agent on the engine and infected area. WD-40 is perfect. Spray on the ignition and fuel system. Pay special attention to the ignition coil wiring connectors and HT leads
[img]C:\Documents and Settings\Administrator\My Documents\New Folder[/img]
check the battery
check these
kurupt39 is offline
Old 18-07-2004   #3
Trader Rating: (0)
Unfortunately, even though the starter motor does turn its not moisture or the battery that is the problem. Anything else that it could be??? I think it must be something more complicated than this as the light comes on the dash.
jclayton
JClayton is offline
Old 18-07-2004   #4
fixitagaintomorrow's Avatar
Trader Rating: (0)
fixitagaintomorrow has donated! United Kingdom
Might be the crank sensor, if it isn't picking up the signal it won't know when to spark.
If the fuel injection warning light is on, there will be a fault code stored in the ecu - might pay to have someone read the codes for you as it should pinpoint the problem straight away.
Pete.
Links: 1242cc cinq, turbo cinq, Cinqs&Seis forum, Clubcento
fixitagaintomorrow is offline
Old 18-07-2004   #5
Trader Rating: (0)
Cheers for that, any idea how much that would cost? it cant be that big a problem with the ECU can it?
jclayton
JClayton is offline
Old 18-07-2004   #6
Trader Rating: (0)
I got a blokey to come round my house, plugged his Snap-On diagnostic computer in and read the codes in a matter of a minute or two. Cost me £25.
Pete.
Old 18-07-2004   #7
Trader Rating: (0)
give me as much info as you can i will consult me haynes manual and the car handbook as well as a mechanic who lives in me street. you just need to tell me what you can bout the car and the suspected problem.
kurupt39 is offline
Old 18-07-2004   #8
Trader Rating: (0)
this may help
[img]C:\Documents and Settings\Administrator\My Documents\instruments.jpg[/img]
kurupt39 is offline
Old 18-07-2004   #9
Trader Rating: (0)
It is a black 1995 (N reg) Fiat Cinquecento, 899CC. Its got a brand new set of spark plugs, and a new set of wheels. The warning light next to the battery comes on when the ignition is switched on, however the car hasnt been starting first time for a little while.
The car runs really well when she starts, however when the car doesnt start, you cant hear the petrol pump flowing the petrol through. However when the car starts you can start the car. Anyone think that it is a dodgy fuel pump?
JC
jclayton
JClayton is offline
Old 18-07-2004   #10
Trader Rating: (0)
you say it is is going through the petrol pump. Has the guide to the buttons i have issued any help. It should help you identify the icon. As mine is an sx also i will go and have a look at mine. I have had a look at my manual and seen that in either the 704 cm engines and the 899 cm engines that the battery that you seem to be identifying is the fog lights which can not be right.
I am not entirelly sure it can be the fuel pump. Also the oil sign comes on when the engine won't start so maybe you should start there. I suggest that you empty the sump and refill it. Try that and see what happens. That can take 15 mins and it can take no time to fill up so give it a go and see.
kurupt39 is offline
Old 18-07-2004   #11
Trader Rating: (0)
er, no - don't bother changing the oil unless it's overdue!
If the engine management warning light is on (little nozzle with a squirt out the end) for more than a few seconds when you start up it'd suggest a fault.
When you first turn on the ignition without starting it, the pump should run for a couple of seconds then stop. If this isn't happening then you may have hit the nail on the head - could be an electrical problem (Pump relay, connections, pump itself or wiring fault)
Pete.
Old 18-07-2004   #12
Trader Rating: (0)
do you think a change of the battery and oil is in order. Will that be of any assistance. Or should he jsut go straight into working on the startin systems and the ignition systems.
kurupt39 is offline
Old 18-07-2004   #13
Cento Boy
surfin_fella's Avatar
Trader Rating: (0)
surfin_fella has donated! Australia
it's not the oil. an oil change won't change anything. If it's not starting first time but then starts and runs fine, it isn't the battery
Sie
Black 96P Cinq Sporting
OMP Strut Brace, Apex -40mm kit, GSR F1i Induction, Pioneer ICE
Union Jackass
surfin_fella is offline
Old 19-07-2004   #14
Trader Rating: (0)
could it be the ignition system. or is that not what could be causing it. I want to be able to know what it is in case i ever envcouter the problem me self.
kurupt39 is offline
Old 19-07-2004   #15
Moderator
Trader Rating: (7)
Steven has donated!
kurupt39, chill out.
You've been offering dodgy advice on both this thread and this thread;
http://www.fiatforum.com/forum/topic.asp?TOPIC_ID=14906
You clearly have no idea what you are talking about so I suggest that you stop pretending you do. If someone comes on here, follows your advice and it damages their car they won't be very happy now. Will they?
Sorry if this sounds harsh but I reckon it needs to be said.
Steve...
Visit my Fiat website; www.forzafiat.com
2001 Brava 1.6 HSX 100, 1994 Uno 1.1 ieS.
Steven is offline
(T) Clonking noise when turning right keef444 Bravo / Brava 2 24-03-2004 02:51
(T) Punto Loosing Fluid, Noisy Belts & Turning philmellor Punto 3 16-03-2004 22:51
(T) *wooooom* noise when turning right... Sando Cinquecento / Seicento 5 17-02-2004 22:57
(G) Scraping Noise when turning right. cordless Stilo 5 16-02-2004 20:59
FIRING ORDER ON FIRE ENGINE simo7923 Panda (Classic) 6 27-09-2003 02:15
