The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Cinquecento / Seicento > Cinq/Sei > Technical
Old 29-06-2004   #1
Principality Retained :)
arseofbox's Avatar
Trader Rating: (3)
arseofbox has donated! United Kingdom
Track rod end
The 1242cc saga continues!!
Not much more to do - connect zorst manifold and downpipe, do OS track rod end, slap the wheels on, fill all fluids then test the bastard.
Prob is simple, I cant get my OS track rod end back in.
I take its just a case of smashing the TRE with a hammer until its securely seated in the housing, so yu can do up the nut!
Ive tried a lot, but dont seem to really be getting anywhere, each time i turn the spanner on the nut, the balljoint pops back out of its housing! It isnt splined is it?
Tom (AofB)
95 Cinq Sporting - Rattly GrpN Catback Exhaust, <font color="black">Buckets</font id="black"> and 3pt Harnesses,Sexy VW styleé dials (that look great, but dont work!! (:D)), 10" Sub and 6x9's, ETech Wing. Lots of Dirt!
1242cc Engine in car, not wired up, need new inlet manifold!!, boot delock soon, K+N still in garage!
arseofbox is offline
Old 29-06-2004   #2
__________
dave's Avatar
Trader Rating: (9)
dave has donated! Saint Kitts and Nevis
You can use fine wet and dry on it and its seat just enough to give it a bit of grip,
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
dave is offline
Old 29-06-2004   #3
fixitagaintomorrow's Avatar
Trader Rating: (0)
fixitagaintomorrow has donated! United Kingdom
Try cleaning the thread on the track rod end to minimise the drag from the nut.
Pete.
Links: 1242cc cinq, turbo cinq, Cinqs&Seis Yahoo group, Clubcento
fixitagaintomorrow is offline
Old 30-06-2004   #4
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
rallycinq has donated! New Caledonia
Certainly not bash it. A constant upwards pressure on the bottom of the TRE, usually a long pry bar. Being right handed the pry bar is on my left shoulder leaving the right hand to tighten the bolt. Quick movements with a spanner can also help
D
Grumpy old git going fast downhill rather than downhill fast!!
rallycinq is offline
Old 30-06-2004   #5
arseofbox's Avatar
Trader Rating: (3)
Upwards pressure on the bottom?
Madness...I cant see it, but i'll give it a go;)
Tom (AofB)
Old 01-07-2004   #6
rallycinq's Avatar
Trader Rating: (1)
A million apologies.
I have been working on cars other than cinqs, where the TRE gose in from the bottom (ooerr missus)
Of course, the Cinq TRE goes in from the top, duh.
Therefore downward pressure on the top of the TRE. I used a jack handle and put the open end over the unused rearward facing brake pipe mount and leant on it as I tightened.
Sorry to confuse.
D
Old 01-07-2004   #7
arseofbox's Avatar
Trader Rating: (3)
So tw*tting it a hammer is the same then??
Tom (AofB)
Old 01-07-2004   #8
rallycinq's Avatar
Trader Rating: (1)
No, constant pressure.
D
Old 20-07-2004   #9
arseofbox's Avatar
Trader Rating: (3)
Hmm..well, I still cant get it in!
Ive tried the constant pressure method (someone standing on the TRE), but the nut just isnt budging!
Ive sprayed it with WD40 in the hope that may help and left it over night, but i get the inpression it wont, any better ideas?
Tom (AofB)
95 Cinq GTi 1242cc - GrpN Catback Exhaust, <font color="black">Buckets</font id="black"> and 3pt Harnesses,Sexy VW styleé dials (that look great, but dont work!! (:D)), 10" Sub and 6x9's, ETech Wing. Lots of Dirt!
boot delock soon, Induction in development!
Old 20-07-2004   #10
rallycinq's Avatar
Trader Rating: (1)
Take all the WD40 off, use IPA or similar, run a die down the thread on the ball joint to clean it. Emery cloth the upright and the taper, no lubricant any where near it, then away you go.
D
Old 21-07-2004   #11
Trader Rating: (0)
As a last resort, if that doesn't work try cutting a small slot in the end of the stud, hold that with a stout screwdriver and use a spanner on the nut.
Pete.
Links: 1242cc cinq, turbo cinq, Cinqs&Seis forum, Clubcento
Old 21-07-2004   #12
arseofbox's Avatar
Trader Rating: (3)
Well, I ended up last resorting in a bit more of an overkill way- angle grinding the nut.
Its off- id say it was the nylon insert in the nut causing the problems
Tom (AofB)
Old 21-07-2004   #13
Trader Rating: (0)
Ah.
That'll be the Nylok then - it's supposed to stop it shaking loose.
Pete.
Old 21-07-2004   #14
arseofbox's Avatar
Trader Rating: (3)
Hmm. Ive got two flats on the TRE, but theres thread thats been unaffected by the grinder. Ive tried an M10 size nut- the only available that Id thought would fit (Was thinking M9 or M10), and the TRE appears to be taking the thread off the nut. Ideas? Or is it a replace the TRE job?
Tom (AofB)
Old 21-07-2004   #15
Trader Rating: (0)
Have you got the right thread pitch?
Fiat are a bugger for using Metric Fine threads..
Pete.
vB code is On
For Turbo owners: Track control arm clamps! Morty Mort Uno 6 19-08-2004 16:03
*HELP* Track rod removal Ali P Bravo/a > Technical 1 30-01-2004 23:47
Track Car James M Leisure Lounge 2 28-01-2004 21:57
CCC Track day report CentoEvo Events 4 30-04-2003 16:52
15th June Track Day 2.0 20v Events 0 07-06-2002 18:02
