The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Cinquecento / Seicento > Cinq/Sei > Styling
Old 06-11-2006   #166
The Thrill of Driving....
J333EVO's Avatar
Trader Rating: (0)
J333EVO has donated!
Re: My seicento Project
Originally Posted by gazzaman2k
@J333EVO
is my fuel reg plumbed in correctly then?
Can't really tell from those pics, but doesn't look like it.
You need to run the fuel pipe feed to t-piece one going to 2nd injector then other going to fuel pressure regulator as it has to be after of the injector its feeding, the return from the regulator then goes to the throttle body top to feed the primary injector as this is controlled by its own inbuilt regulator found inside the throttle body and normally sealed by blue wax, you can unpick this and turn clockwise to increase pressure, factory its anywhere between 0.8-1.2bar, I suggest running at 1.4bar, and 2.5bar on 2nd injector and make sure its all set up on a rolling road with someone who knows what they are doing otherwise you coudl either be very lean or very rich.
As you have it i can see a t-piece after the regulator meaning that it will not work.
I suggest that you invest in a fuel pressure gauge like the ones found here www.fuelsystem.co.uk and check all the pressures, remember to get the pressure you need to put the gauge in before the regulator to get the pressure.
1992 Lancia integrale EVO1;
1995 Toyota Celica GT4 ST205;
2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's)
J333EVO is offline
Old 06-11-2006   #167
kritip's Avatar
Trader Rating: (3)
kritip has donated! United Kingdom
Did you not transfer the old rubber dust protector and spring cover from the old shocks onto the new one? I thought they needed to be?
Also, apparently its best to move the fittings over to the new hoses, the main area of contact it on the body, behind the damper, looks like there will be lots of contact there.
Really appreciate all the pics though, really make each little update exciting lol
Kristian
Black Seicento Sporting mk2
1242cc 16V conversion finished and removed!
Megasquirt installed, a constant evolution
1368cc and 6 speed running great now
My Members Motors thread
kritip is offline
Old 06-11-2006   #168
Turbo MPI Seicento
gazzaman2k's Avatar
Trader Rating: (0)
gazzaman2k has donated! United Kingdom
how do i know what bar the fuel will be running at on 2nd injector? it will be a direct feed into the 2nd injector from the fuel tank? all that the injector controller will do is open/close the injector to allow more or less fuel in?
do i use the reg to power both injectors or just the 2nd injector? or just the standard one?
the way i have it linked up is if you check the pic below which is powering both injectors at the mo can change this next time if wrong.
@ kritip
i tried to transfer them over but they had long gone and perished didnt know where sells new ones so left off
Project Seicento
gazzaman2k is offline
Old 06-11-2006   #169
bad_boy_cinq's Avatar
Trader Rating: (0)
Coming along very nice, good work. Liking the intercooler keep up the good work.
Blue Cinquecento 1242
15" Alloys, Lowered 60mm, 40mm Tb, McKcrich chip, Custom Door Builds
Yellow Cinquecento turbo
bad_boy_cinq is offline
Old 06-11-2006   #170
J333EVO's Avatar
Trader Rating: (0)
The way you have all you are pressurising is the fuel from the tank to the regulator everything thereafter is not pressurised by it at all making it redundant, but by the regulator inside the throttle body.
I will explain again, the regulator only pressurises fuel before it, not after it. Imagine blowing down a straw and squeezing it smaller it would be harder to blow down as the pressure before your fingers would increase, after your fingers its no different, same principle.
So you run the fuel line direct to a T-piece before the 2nd injector and the line off the T-piece to the regulator, this will pressurise the fuel upstream of the regulator i.e the 2nd injector, the return from the regulator then goes to the throttle body where by its lower pressure is set by the inbuilt regulator, you can clearly see this in the pics of my car.
HTH, Aaron.
J333EVO is offline
Old 06-11-2006   #171
Turbo MPI Seicento
gazzaman2k's Avatar
Trader Rating: (0)
ah i get you now thats made it alot clearer to understand, so basically i want to just do a direct line to the 2nd injector and use the fuel reg on the standard injector as that cheers
Name:	fuel reg 2.jpg
Project Seicento
Old 06-11-2006   #172
Moderation in Moderation
GhostWKD's Avatar
Trader Rating: (0)
GhostWKD has donated! United Kingdom
Just thought i'd add to this as its something i've been pondering aaron, but do you think that its possible my cinq has already had the fuel pressure played with? (well not so much possible more probable?) as its gone 6 years+ of being turbo'd without a rebuild at all (touching wood by the way lol just incase!) so if it is running lean it cant be running *that* lean if you catch my drift? (like i said at pod, pretty sure its overfueling by the flames etc)
Also looked on ebay and by the looks of it a fuel pressure gauge is going to be pretty cheap to get hold of
My Cars:
Broken Rev1 MR2 Turbo
Rev1 MR2 Turbo - Shiney 17's, XS Power Intercooler, Japspeed Exhaust, Apexi Indcution, Blitz EBC, Blitz Turbo Timer
GhostWKD is offline
Old 06-11-2006   #173
J333EVO's Avatar
Trader Rating: (0)
No this is what you need to do
Alex i do not believe that VAD adjusted the fuel pressure as the was seal would have to have been removed from the pressure regulator inside the throttle body. As i said at Santa pod, even when my car was on full settings on MF2 mine still ran lean. i believe that this is the single reason why they stopped doing hi-boosts as if you got a car running fuel pressure of 0.8bar (factory set is between 0.8-1.2bar) and ran 0.6bar boost you get fuel pressure of 0.2bar i.e a dribble not a jet of fuel. This is why they capped hi-boosts to 0.5/6 bar anymore and the car would last maybe a few thousand miles if lucky, you know what happened to Alex's car.
And as you have fitted a 40mm throttle body you have increase area by 25% so have in fact leaned the fuel mixture down.
There are a few on ebay and such like this I know of one integrale owner and reporting no problems http://cgi.ebay.co.uk/Adjustable-Per...QQcmdZViewItem
J333EVO is offline
Old 06-11-2006   #174
GhostWKD's Avatar
Trader Rating: (0)
will get it looked into asap either way and saw the regulator with gauge and was thinking maybe 2 birds with 1 stone kind of thing
My Cars:
GhostWKD is offline
Old 08-11-2006   #175
Trader Rating: (0)
where do you get a seicento bodykit like that from?
having struggle finding bodykits!
also aswell where can i find some decent alloys for a seicento?
b29a07z89 is offline
Old 08-11-2006   #176
Turbo MPI Seicento
gazzaman2k's Avatar
Trader Rating: (0)
i got the bodykit from ebay decent alloys for seicento...... hmmm
smoors, KN minators, khan racing, wolfrace octane, depends what kind your looking for theres loads to choose from
Project Seicento
Old 08-11-2006   #177
Turbo MPI Seicento
gazzaman2k's Avatar
Trader Rating: (0)
it was my birthday today lol package from hong kong great way to avoid tax hehe
its tiny will look great somewhere in the car (not decided yet )
ID:	20663  Click image for larger version
ID:	20665  Click image for larger version
ID:	20667  Click image for larger version
ID:	20669  Click image for larger version
Project Seicento
Old 09-11-2006   #178
V.Owen-V.Yellow-V.500
OXCiD3's Avatar
Trader Rating: (1)
OXCiD3 has donated! United Kingdom
Sorry, call me a prick.. but what is that thingy?
~~ REDDOT Racing ~~
RIP REDDOT JTD
"Luigi follow only the ITALIAN cars"
OXCiD3 is offline
Old 09-11-2006   #179
T.E.D.
Trader Rating: (1)
T.E.D. Jordan has donated! United Kingdom
Fueling heaven
Jordan
Total Engineering Developments
T.E.D. Jordan is offline
Old 09-11-2006   #180
GhostWKD's Avatar
Trader Rating: (0)
and boost control heaven
btw if you spot another cheap boost controller gaz give me a shout
fitting t/timer at weekend if it turns up i think
My Cars:
GhostWKD is offline
vB code is On
Fiat Seicento HGT EvilJaxx Cinquecento / Seicento 7 05-07-2008 18:12
Seicento Gearbox Problems Sporty_5_Seicento Cinq/Sei > Technical 11 28-09-2007 11:42
Plenty of Seicento and Abarth bits!!! nwallace Auction Watch 6 06-02-2006 15:16
seicento sporting, nearly complete project gaz.d Auction Watch 5 17-10-2004 20:07
