| this is where my aerial has snapped how can i put a screw in one in ? would i have to remove baseplate, how i tried shifting it no luck how easy is it to fit a screw in one to this set up cheers
| i am | Re: aerial help not really clear by your pic which bit has snapped.has it actually broken the base rather than just the antenna? easiest way is to get one from the scrappys as the base is easy to change | ||
| | #3 | ||
| Re: aerial help its the aerial that has snapped then as the x is where it screws in the end of antena got like claws that like let it move up and down snapped there can i just get a screw in one like remove base or something cheers
| | #4 | ||
| Re: aerial help i had a similar problem and replaced all of the components under the black dome thingy. found a seicento for breaking on ebay and bought the components from him. you will be looking at between £6-10 for the parts. good luck. JOB DONE!!! hope this helps rich
| | #5 | ||
| Turbo MPI Seicento | Re: aerial help the ariel just unscrews from the top of the car just pu the ariel down so it will be flat with the car roof... look on top and youll see a screw, undo that and the base just comes free, i got a brand new ariel from of the cassified section of this site for £5 mine snapped in exactly same place gaz
| | #6 | ||
| Re: aerial help I think this should sort your problem out mate: http://cgi.ebay.co.uk/Fiat-Aerial-Ba...QQcmdZViewItem cheers rich
| | #7 | ||
| save me iam bored | Re: aerial help agai n try you dealer bet its not much
| | #8 | |||
| Ah. Not good... | Re: aerial help
| | klaus23 | Punto | 4 | 08-08-2007 16:27 |
| Stilo aerial - amplifier? | andy_tech | I.C.E | 20 | 29-10-2005 15:27 |
| | Helz | Bravo / Brava | 4 | 07-08-2004 05:54 |
| | 1.2sxPunto | Punto | 9 | 19-11-2003 01:18 |
