| spacers Hi all. I have just got some new 15s for my cinq. The front went on fine. but tight under there. but went to put the rears on and they hit the rear arm. what size spares do i need in the rear. Thanks Guys
| i am | Re: spacers well perhaps the wheel specs would help? | ||
| | #3 | ||
| Re: spacers Wolfrace 15in Street Octane wheels with195/45/15 6.5J the pcd was 100 but got the wheel nuts. and the offset was what ever the cinq offset is. i had to wait for them to be made or something.
| | #4 | ||
| www.niimc.net | Re: spacers nice wheels mate. Think ive 5mm spaces on my 15"s but i also had to trim some of the rear arm and re-weld it on my seicento.
__________________ SEI:-Broom Yellow, Making a return BARCHETTA:- still in garage PANDA 100HP:- Gone ![]() Alfa 147- JTD power Ducato Camper | ||
| | #5 | ||
| The Thrill of Driving.... | Re: spacers on a 6 1/2" wide wheel the off-set will not be the same as a standard 5 1/2" wheel, there are a lot of threads on off-sets why not read them and see what you need.
__________________ ![]() 1992 Lancia integrale EVO1; 1995 Toyota Celica GT4 ST205; 2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's) | ||
| | #6 | ||
| Re: spacers i dont really want to cut my rear arm or anything like that. Thanks
| | #7 | ||
| www.niimc.net | Re: spacers Its not cut, its the way the metal is joined, you have like 2 wings and ive just had those trimmed back and strenghened to fit the wheels
| | #8 | |||
| ...done | Re: spacers
however, i will say it is very unlikely they will be the correct cento offset. they will most prob be about 36 or 38mm. for 6.5 wide wheels u will prob need to get them down to about a 26mm offset to make sure they dont foul anythin on suspension etc. but they might stick out from the arch a bit and will def rub if the car is lowered at all.
__________________ R97 cinq 1242 <Ex Team Anthracite > (now sold) | |||
| | #9 | ||
| Re: spacers yeah when i ordered them i ask fot the offset to be 36. and have just asked the guy and he said. They where 100 PCD and 36 offset. he gave me longer wheel bolts. The front went on sweet as a nut.
| | #10 | |||
my suggestion.... 10mm hubcentric spacers, and longer bolts to match!! but they will almost def stick out from the arches a bit so the tyres might rub on the arches if the car is lowered at all!
| | #11 | ||
| Re: spacers my front ur write i can get a front lock but its o.k to drive. my car in on standad sporting suspention.
| | #12 | |||
IMO i would say get some 10mm hubcentric spacers as the offset is a bit too high with that width wheel, i can point u in the direction of some hubcentric ones if needs be. but at the end of the day its your car so its your call
| | #13 | ||
| Re: spacers yeah wear can i get the spaces from. im going to need longer bolts aswell. do u think 8mm would work?
| | #14 | |||
http://www.performancefx.net/wsfiat.htm 10mm hubcentric spacers, and they come with longer bolts. however i will say that u might need to get even longer ones dependin on the length of the ones they supply... cause i bought the 15mm ones from there, and the bolts they supplied werent long enough.
| | #15 | ||
| Re: spacers so ill need the type 11 ones???? where did u get ur long bolts from mase
| | peaster2k | Cinquecento / Seicento | 0 | 26-09-2005 22:05 |
| | NSMG | Cinquecento / Seicento | 6 | 25-07-2005 18:55 |
| | Seicento Racer | Cinquecento / Seicento | 10 | 14-04-2005 17:01 |
| | Luciano | Cinquecento / Seicento | 9 | 22-08-2003 21:39 |
| | Luciano | Cinquecento / Seicento | 7 | 20-08-2003 05:02 |
