| Debadging an SX I've looked all over the site for a post about debadging a Cinqu SX. Which badges have holes in? Or are they all stuck on? I believe the rears are stuck on, but im uneasy about the front..
| ***** Friendly | Re: Debadging an SX the front ones got a hole and a little sunken bit and im pretty sure the rears are just stuck one, as the boot lids the same as the sporting, which are always being debadged
| | #3 | ||
| Re: Debadging an SX What do you recommend about the front? You sure its not stuck on?
| | #4 | |||||
![]() you should see the back of the badge sticking through the hole
| | #5 | ||
| Re: Debadging an SX So I should see some little pins stuck through my bonnet?
| | #6 | |||||
![]() it might be cover by insulation, so have a good look
| | #7 | ||
| Re: Debadging an SX I'll do it tomorrow and report back on my findings, its really damn cold right now :P I also need to change my fanbelt.
| | #8 | |||
| RIP L181 VBB | Re: Debadging an SX
You need to buy a fanbelt and a haynes for the other bit ![]() EDIT someone has deleted the debadging sticky
__________________ ![]() 2001 Modded Sei Sporting - GONE!! 1998 Ford Mondeo 1.8LX - P/X'ed 2002 02 Ford Focus 1.6 Zetec w/ Climate Pack! | |||
| | #10 | ||
| Ah. Not good... | Re: Debadging an SX All the rear badges are stuck on. Heat them up with a hairdryer a bit first, then use an old credit card or fishing line to remove badges, clean off any adhesive left behind, T-Cut to blend in paintwork. Front one, IIRC, is held with with 2 pegs and a nut/bolt arrangement. There is also a circular shaped depression behind the badge that would have to be filled | ||
| | #11 | ||
| Re: Debadging an SX ive tried to debadge the bak of my cinq but theres loads of sticky left behind how will i get it off ive tried all i can think of
| | #12 | ||
| Forum moderator | Re: Debadging an SX As I found out the other day, you don't even need t-cut to blend it in. I used tar remover (allegedly safe for paintwork) to get the sticky off (with lots of elbow grease) and the cloth was red by the time I was finished. That never happened with the Brava!
__________________ | ||
| | #13 | ||
| i am | Re: Debadging an SX did you try some elbow grease? | ||
| | #14 | ||
| Wants a Tipo | Re: Debadging an SX any chance i could have the cinquecento sx badges you are/have taken off? pleeeeeeease
__________________ Peeing off the whole planet one person at a time![]() TURBO SEICENTO FOR SALE | ||
| | #15 | |||
| | Si - Punto | Punto | 9 | 22-10-2005 15:40 |
| MK2 boot debadging | Bushboy | Tipo | 2 | 12-09-2005 23:46 |
| | AppleSei | Cinquecento / Seicento | 10 | 16-05-2005 00:09 |
| | lee1980sim | Cinquecento / Seicento | 7 | 09-03-2005 22:39 |
| | James3LF | Punto | 3 | 01-07-2004 18:18 |
