The FIAT Forum
Old 29-12-2005   #1
scottc1088's Avatar
Trader Rating: (2)
switch led's
i bought the led kit off ebay for my switches about a month ago and fitted them to the car, after about 20mins 3 of them blew so i contacted the seller and he sent me some more which i didnt fit as i was getting another cinq
now iv got my other car iv fitted them and after a few hours nearly all the ones in the switches have blown again
is there a known reason why they keep blowing? as theres no point keep replacing them if there going to blow again within a few hours
scottc1088 is offline
Old 29-12-2005   #2
Born to be riled
Steve-0's Avatar
Trader Rating: (0)
Steve-0 has donated! United Kingdom
Re: switch led's
Perhaps the wrong resistor values were used?
Steve
Steve-0 is offline
Old 29-12-2005   #3
scottc1088's Avatar
Trader Rating: (2)
Re: switch led's
the only resistor i had to use was on the headlight switch and he provided the resistor already soldered to the led
Old 29-12-2005   #4
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: switch led's
well it sounds to me that there using either poor quality led's or the led's cant handle the 12v.
even with 12v led's i would be tempted to put a resistor in to gaurd against power surges.
i need to get around to doing this.though i'll be modding my own led's to fit.
too tight to pay someone
custard is offline
Old 29-12-2005   #5
Born to be riled
Steve-0's Avatar
Trader Rating: (0)
Re: switch led's
Led's are only 1.5 to 3 volt, hence you need a resistor on every led.
That's why their poppin, innit?
Steve
Steve-0 is offline
Old 29-12-2005   #6
scottc1088's Avatar
Trader Rating: (2)
Re: switch led's
nope theres already a resistor built in there
Old 29-12-2005   #7
i am
custard's Avatar
Trader Rating: (1)
Re: switch led's
Steve
thats why i referred to 12v leds.assumed this is what the seller used.i'll be using standard 3v ish led's on mine. just need to order the correct resistors as all off mine are rated for xbox use on a 5v feed.
also deopending on how you wire them you dont always need one resistor per led
custard is offline
Old 30-12-2005   #8
Rob_Randomcruisers.co.uk's Avatar
Trader Rating: (-1)
Re: switch led's
most of mine poped aswell and the ones for the elecy windows eint a gud fit and one of them has poped aswell.
only ones that work good are the ones for the dials but even then the speedo needle dont light up doh!
if anyone finds ones that work fine and dont pop please let me know
Rob_Randomcruisers.co.uk is offline
Old 30-12-2005   #9
Born to be riled
Steve-0's Avatar
Trader Rating: (0)
Re: switch led's
Try maplins, 12v led's are 20p each !
Steve
Steve-0 is offline
Old 30-12-2005   #10
Trader Rating: (-1)
Re: switch led's
kool ill have a gander 2moz then cheers
Old 01-01-2006   #11
Slippy's Avatar
Trader Rating: (0)
Slippy has donated! United Kingdom
Re: switch led's
You'll still best use a resistor surely as the alternator usually puts out around 14.4v this still may be a little excessive for a 12v led.
Any one know for sure?
http://www.fiatforum.com/gallery/dat...new-sig-an.gif
You choose well. The red Sei is gorgeous, probably the nicest Sei on the forum.
Originally Posted by mekinhos
That's the nicest Seicento I've ever seen
Amazing
Slippy is offline
Old 01-01-2006   #12
Trader Rating: (-1)
Re: switch led's
went to maplins yesterday and they only do 12v leds in red green and yellow how boring!!
i could use smaller voltage ones with a resister but i dont think it would fit on due to the casein of the led behind the switches???
Old 01-01-2006   #13
i am
custard's Avatar
Trader Rating: (1)
Re: switch led's
as i said i'll most likely be fiddleing around with some on mine in the next couple of weeks.
i'll most likely be going with 3mm led's with resistors so hopefully will have more practical info
custard is offline
Old 01-01-2006   #14
Trader Rating: (-1)
Re: switch led's
sounds gud let me know how it goes and what wattage the leds are
cheers rob
Old 01-01-2006   #15
i am
custard's Avatar
Trader Rating: (1)
Re: switch led's
cheers rob
led's will be around 3.3v if i go for blue. should be able to solder in a resistor externally to the buld holders.
well thats the plan in my head
custard is offline
(S) FAQ - Dash Switch Illumination Little Red Devil Cinquecento / Seicento 21 02-11-2007 18:34
(G) Engine Under Power When Switch On Air-cond simonyap Bravo / Brava 0 22-04-2005 09:19
(S) dash switch LED's mase Cinquecento / Seicento 7 06-12-2004 20:22
(G) uno mk1 ignition switch wiring coolhand_mike Uno 0 06-10-2004 23:58
(G) Simple question - hope it's a simple answer! DotSPF Uno 6 11-11-2003 23:18
