| exact offset what the exact off set for the cinq? i read in offical publications that the offset is ET36 heard on here and other places that the ET is 29, ppl puting anET35 on the front but need ET29 on the back;)[?];) its so confusing and fustrating[:(!]:) can anyone help me please[?][?][?][?] karl 96 cinq 900 sx
| basically its because there is nothing around the front wheel for the wheel to catch on therefor it isnt to critical but at the back the wheel will catch on the suspension arm if the offset is not correct and so the wheel will need pushing out by a spacer in order to clear this i just got my alloys today and they are et 35 and so i need spacers but the only place round here selling them are halfrauds who stock 9mm spacers and thats it
| | #3 | ||
| You will need a minimum offset of 32mm on the rear My Car is now for sale, A total one-off, head turning bargin!!!
| | #4 | ||
| what the maximum? seen some alloys that have et35 6" wide 14"diameter, they claim no modification is required. karl 96 cinq 900 sx
| | #5 | ||
| I think centoevo meant a *maximum* of 32 on the back, not *minimum*
| | #6 | ||
| is there anywhere on the net that sells 6mm spacer at a good price?? also how can i find out hte length of wheel bolt that i need will standard fiat alloy wheel bolts fit as they said they didnt know thanks lads
| | #7 | ||
| No i meant minimum, it can get quite confusing this offset malarky but i'll try and explain. The lower the offset the more the wheel sticks out. The offset is the distance from the surface which touchs the brake drum or on the from the brake disk to the centre of the alloy. If you add 3mm spacers onto a 35mm alloys like i have, it reduces the offset as the surface of the alloy which mounts onto the car is made bigger by 3mm so the surface is then 3mm closer to the centre of the alloy hence the offset is reduced. Get it??? My Car is now for sale, A total one-off, head turning bargin!!!
| | #8 | ||
| Exactly - so you need a maximum of 32 on the back. Anything higher, and it will be brought too far into the car. A minimum of 32 would mean that anything higher will fit, which is the wrong way round.
| | #9 | ||
| <blockquote id="quote">[size=1] face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Luciano A minimum of 32 would mean that anything higher will fit, which is the wrong way round. <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote"> Eh? you could have wheels with 20mm offset if you wanted and they would still fit, i don't get what your saying. [:o)] My Car is now for sale, A total one-off, head turning bargin!!!
| | #10 | ||
| so et32 would have a grater distance between the suspension and the tyre, than et35 which would have a smaller distance between the suspension and the tyre?:( karl 96 cinq 900 sx
| | #11 | ||
| CENTO - exactly!!!!!! You said "You will need a minimum offset of 32mm on the rear". and then you go onto say that ET20 would fit! (quite right) So I was correct, ET32 is the maximum offset, NOT the minimum!
| | #12 | ||
| i can get my 9 mm spacers machined down to wotever i like so shall i get 3mm taken off them to make them 6mm and the offset 29 or shall i get 6mm taken off them to give an offset 32 or does it really not make a damn bit of difference as long as the wheels fit!?
| | #13 | ||
| Why not fit the wheels with the spacers, measure the clearance between the rim and suspension arm, and then trim the spacer to give 3mm or so clearance? Pete. Cinq sporting 1242cc Cinqs&Seis Yahoo group Clubcento
| | #14 | ||
| Join Date: Jun 2003 Location: Malpas, Cheshire, United Kingdom.
Thanks: 0 Trader Rating: (0) | Just got a set of 6mm spacers for £12, ask at a motor factors Steve Wright http://www.chestermodels.com/fiat http://www.offroading.net
| | #15 | ||
| :D Oh yeah i see now, sorry Luciano brain not working :D My Car is now for sale, A total one-off, head turning bargin!!!
| | AquaSpirit | Cinquecento / Seicento | 26 | 1 Week Ago 12:09 |
| | goober | Bravo / Brava | 2 | 21-06-2004 02:03 |
| | wagon_boy | Stilo | 3 | 12-05-2004 01:48 |
| | K4RL | Cinquecento / Seicento | 5 | 03-05-2004 02:15 |
| | CHARLIE-CINQ | Cinquecento / Seicento | 1 | 30-11-2003 05:33 |
