The FIAT Forum
Old 18-12-2004   #1
vc_1985's Avatar
Trader Rating: (0)
help!
rite im fittin my bonnet scoop today its off a ren 19 and i need to cut a whole in my bonnet so how do u cut it out without f u c k i n it up??
vc_1985 is offline
Old 18-12-2004   #2
Banned
Trader Rating: (2)
Bushboy has donated!
Re: help!
get a rotary cutter from B&Q.. cost about £20 and they do a great job at everything they say they can.
I dont mean an angle grinder.. a rotery cutter is a mini spinning thing that u get get mini angle grinder blades for. really good for detailed cutting
Bushboy is offline
Old 18-12-2004   #3
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: help!
And let the cutting disc do the work, don't try and force it through the material.
D
rallycinq is offline
Old 18-12-2004   #4
vc_1985's Avatar
Trader Rating: (0)
Re: help!
ok ill get 1 tomoz cheers!
vc_1985 is offline
Old 18-12-2004   #5
Drives a Punto
Trader Rating: (0)
joecinq has donated! Yemen
Re: help!
take some piccy's as i'd like to see how it goes
3rd Fiat - luck as good as ever
joecinq is offline
Old 19-12-2004   #6
Banned
Trader Rating: (2)
Re: help!
rallycinq is right.. if u force it the blade will catch and ital end up flipping out and cutting the surface and ruining ur finish.
just be patient and take it slow.
oh btw, in my experience, Only the b&Q warehouses well rotary cutters... the normal B&Qs dont seem to stock them around where i live. My 2 b&Q warehouses stock 2 types, the dremel one and a less known branded one. i have the less known branded one (it was cheaper and came with more blades etc) and it does the job fine, and the better quality dremel blades are interchangable too
Bushboy is offline
Old 19-12-2004   #7
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
Re: help!
do you mean holesaws - that have a drill bit in the middle for a guide and they attach to a drill?
i'd use something like that if it were me.. but slowly so you dont heat the area up and bugger the paint with the heat (seen it happen on other painted metal surfaces)
arc is offline
Old 19-12-2004   #8
rallycinq's Avatar
Trader Rating: (1)
Re: help!
Not the drill bit, a 'dremel' clone is the required tool.
D
Old 19-12-2004   #9
Banned
Trader Rating: (2)
Re: help!
yet... the dremel style tool is that u need. its like a mini circular saw/angle grinder all in one
Bushboy is offline
