| | #16 | ||
| AKA Dan | Re: Blue Lights Just found them . Do you think red ones will show up quite well?
__________________ http://www.fiatforum.com/gallery/dat...ed-4_copy1.jpg | ||
| | #17 | ||
| Moderation in Moderation | Re: Blue Lights umm not sure tbh, but could always remove the dim dip fuse (like arc has done (and maybe ash not sure?)) so when u have the lights switched on on first notch u only have the sidelight bulb lit up, in which case they would show, not sure how much they'd show with the lights on though, if you get some get pics
__________________ Lots of mods Rev1 MR2 Turbo - Sold pending collection RX7 Twin Turbo - Because real men play with twins | ||
| | #18 | ||
| AKA Dan | Re: Blue Lights There only cheap so might buy blue and red! Will probably order them in a minute.
| | #19 | ||
| Re: Blue Lights I put my Xenon white sidelights yesterday and took out the dim/dip headlight fuse.. They look sweet Will post a pic in a min
| | #20 | ||
| Re: Blue Lights Old sidelights (Meant to be "blue" ones) ![]() ![]() New white LED sidelights ![]()
| | #21 | ||
| Re: Blue Lights will any of the 501s on ultra leds work as side lights?? dose it require abit of inventive wiring?? chears
__________________ Not so much a panda, more of a grizzaly bear. GRRRR | |||
| | #22 | ||
| Yellow Cinq Abarth :D Join Date: May 2004 Location: In A Place...... Far Away From You
Thanks: 0 Trader Rating: (0) | Re: Blue Lights Yeah 501 are the sidelights type, so 501's will work as sidelights and just plug stright in.
__________________ Ashley Past - Yellow Abarth Cinq Sporting, Current - Black Suzuki Ignis Sport Also Red 1970 Type 1, 1.6 Beetle, Wit WIDE Arches! | ||
| | #23 | ||
| AKA Dan | Re: Blue Lights Are different colour sidelight bulbs legal? even if you dont use them apart from shows, meaning that you just use the headlights?
| | #24 | |||||
| Re: Blue Lights
http://www.ultraleds.co.uk/product_i...roducts_id=525
| | #25 | |||
oh and they're always on with the headlights too (unless you remove the fuse )
__________________ Lots of mods Rev1 MR2 Turbo - Sold pending collection RX7 Twin Turbo - Because real men play with twins | |||
| | #26 | ||
| AKA Dan | Re: Blue Lights If i remove the fuse will i have to swap them over to originals for the MOT?
| | #27 | ||
| Moderation in Moderation | Re: Blue Lights im pretty sure mot requires sidelights (as parking lights depend on the sidelights having a fuse and well working ) so will have to be swapped to originals for mot time
| | #28 | ||
| AKA Dan | Re: Blue Lights Just wondering. I have a 'tolerant' MOT'er anyway.
| | #29 | ||
| Re: Blue Lights what dose the dip/dim fuse accualy do for us not in the know???
| | #30 | ||
| Moderation in Moderation | Re: Blue Lights when you have your lights on the first notch, it has the sidelight bulb lit up, and the dip light is on but dimmer than normal, the dip/dim fuse is the one for the dimmed circuit so that when you have it on the first notch only the sidelights are switched on
| The person b4 me 3 | polecat | Leisure Lounge | 6015 | 12-11-2008 12:17 |
| | cholmes0305 | Uno | 3 | 29-04-2004 19:40 |
| | Q TOY | Bravo / Brava | 7 | 01-03-2004 19:29 |
| | custard | Cinquecento / Seicento | 12 | 15-01-2004 01:02 |
| instrument lights / reversing lights | fenderman | Ulysse | 3 | 17-11-2003 22:25 |
