The FIAT Forum
Old 14-11-2004   #1
neilio's Avatar
Trader Rating: (0)
spraying interior panels...
hi, iv got a sei sporting, and im slowly in the process of spraying interior panels. need some help though! im trying to get rid of the horrible texture on the plastic and make it smoooth but im not having much luck. can anybody recommend suitable filler that i can apply and then smooth, or something along those lines??? cheers!
Yellow - one of the best colours to show off the dirt, muck and dead bugs on your car!
neilio is offline
Old 14-11-2004   #2
AKA Dan
D4NS's Avatar
Trader Rating: (0)
D4NS has donated! United Kingdom
Re: spraying interior panels...
You COULD use p38, which is for fine marks on body work. It should work fine and can be sanded easily to any shape you want. Its easily found in halfrauds near the spray paint... Hope this helps. Dan
D4NS is offline
Old 14-11-2004   #3
Moderation in Moderation
GhostWKD's Avatar
Trader Rating: (0)
GhostWKD has donated! United Kingdom
filler primer
My Cars:
Not v modded parts Rev1 MR2 Turbo
Lots of mods Rev1 MR2 Turbo awaiting UK Reg then for sale
Soon: S14a 200sx
GhostWKD is offline
Old 15-11-2004   #4
hi friends :waves:
Liam's Avatar
Trader Rating: (0)
Liam has donated! United Kingdom
Try scrubbing with washing up liquid, hot water and steel wool or brillo pads.
The soapy water will rid the part of silicone from dash cleaners and the brillo pad will rough up the surface for adhesion with plastic primer.
After paint, it looks like this:-
Liam
Name:	Copy of Interior.JPG
CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline
Old 15-11-2004   #5
MotorWorldChink's Avatar
Trader Rating: (0)
I had mine sprayed by a pro. Don't think he sanded or anything. You'll need plastic primer anyway which lays quite thick and by the time you've put 5 or 6 layers of paint and 3 or four of laquer your gonna be virually smooth anyway
MotorWorldChink is offline
Old 15-11-2004   #6
neilio's Avatar
Trader Rating: (0)
plastic primer? is that any different from normal primer? im pretty sure i did buy some of that from halfrauds and used about 4 coats, along with ages of sanding but it still didnt get my panels smooth (talking about the lower door pockets) so im kinda lookin for some proper filler like stuff
neilio is offline
Old 16-11-2004   #7
hi friends :waves:
Liam's Avatar
Trader Rating: (0)
It is different, Plastic primer is for spraying bodykits and it can fill imperfections and also flex and not break.
Filler will only make it a mess, eh, have you tried Plastikote or do you want it body coloured?
PM fixit and he'll advise as this pic below shows, he went a tad mental and painted everything!
Liam
Liam is offline
Old 16-11-2004   #8
neilio's Avatar
Trader Rating: (0)
nah i havent tried plastikote, and i want the panels smooth like bodywork! i just think the ones i tried to do had a deep texture which didnt help
neilio is offline
Old 16-11-2004   #9
taffy git
gaz.d's Avatar
Trader Rating: (2)
gaz.d has donated! United Kingdom
an electric sander should strip the panels bare
it will also give it a good key for filler primer, give a few coats of this, sand down each time, then a minimum of 4 layers of a top coat, again sand down each time, then maybe 3 coats of laquer - you guessed it sand down each time
Gaz
Marea Weekend
gaz.d is offline
(S) Spraying Calipers and rear drums SlinK Punto 14 19-11-2004 21:15
(S) Spraying badboyz016 Cinquecento / Seicento 4 17-06-2004 14:59
(S) Spraying Interior? GhostWKD Cinquecento / Seicento 10 24-05-2004 05:02
(G) spraying an mk2 bumper Mike-MK2 Punto 21 19-04-2004 04:29
(S) Spraying mirrors?? ichi Punto 17 18-04-2004 08:48
