| This parrot is no more... | My front end! what youll think. Bit chav but it sure gets the air flowing. Going to have the whole bumper repainted soon so the silver mesh will be yellow to and wont stand out as much.
__________________ ++Ducati fund - £150 (needed around 2k)++ | ||
| Re: My front end! When I bought my sei it had HORRIBLE silver mesh in there, and a job done really badly. Yours looks pretty neat. I sprayed mine gloss black, I think that'd look quite nice on yours too dude =) not bad though. Luke.
__________________ Total n00b | |||
| | #3 | ||
| This parrot is no more... | Re: My front end! Cheers. I did think of satin black but it will be a arse to spray now the mesh is glued in! cant stand shabby work. Ive done mine for a reason also. I am running a p75 1.2 engine and it really seems to get hot under the bonnet now. bit worried about when I get it down the track. I have also cut out all the other vents that are normaly blocked off if you aint noticed :P
__________________ ++Ducati fund - £150 (needed around 2k)++ Last edited by craigb244; 23-07-2008 at 22:35. | ||
| | #4 | ||
| mad bad and very very old | Re: My front end! Now try and work out a way to get the hot air out. If it can't go anywhere, then it will just stall in the engine bay getting hotter and hotter. Cheers PD
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #5 | |||
vent the wheel arch liner by cutting slots and bending them to stop crap hitting the radiator. put some washers under the bonnet hinge to lift the rear of it up. and remove the rubber seal strip. Hopefully this will make a bit of a vacume at speed to suck the hot air from the top of the engine and cold air thru the front. think it will work?
__________________ ++Ducati fund - £150 (needed around 2k)++ | |||
| | #6 | ||
| Re: My front end! Sounds like a good idea. I had the same problem, my mesh was bonded in, and with a struggle to remove the front bumper...it was, sorry but, it was a b!tch. So I settled for masking it off very carefully and lining the other side with news paper so not to spray the radiator or other components =) Your job would be better than mine I can imagine ha. Luke.
| | #7 | |||
Only one other wee thought, if the mesh is very fine it can actually stop air coming in, so be gentle during testing till you know it cools. Cheers PD
__________________ If it has pistons or tits, its going to be expensive. | |||
| | steve38 | Cinquecento / Seicento | 6 | 03-06-2008 13:03 |
| | bassy-alex | Cinquecento / Seicento | 24 | 07-12-2006 17:42 |
| | stilophil | Stilo | 8 | 28-09-2006 09:59 |
| front end damage | super_padge | Bodyshop | 4 | 21-06-2006 12:15 |
| My New Front End | Bushboy | Members Motors | 21 | 28-06-2004 17:57 |
