The FIAT Forum
Old 24-03-2008   #1
Trader Rating: (0)
gear knob
hw do u take the gear knob off a fiat seicento ive had a go at twisting and pulling and its just not budging at all any ideas ? cheers xx
safc_seicento is offline
Old 24-03-2008   #2
Eight Valves.
willieboy's Avatar
Trader Rating: (0)
willieboy has donated! United Kingdom
Re: gear knob
if its the sporting its connected to the shaft as part of the push down reverse system the same as a cinq i think
Originally Posted by dave View Post
its not a choice, and you cant get pills to make you straight either
willieboy is offline
Old 24-03-2008   #3
Brooky's Avatar
Trader Rating: (1)
Re: gear knob
theres a guide
16v cinq with ITB's
Brooky is offline
Old 24-03-2008   #4
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
AppleSei has donated! United Kingdom
Re: gear knob
As brooky said theres a guide with pics, but you have to hacksaw it off, however the OMP adaptor has apparently ceased being made for these cars, you need this to be able to select reverse.
Weather there is an alternative being made i dont know so dont go sharpening the hacksaw blade till you have got all the bits needed.
2001 Modded Sei Sporting - GONE!!
1998 Ford Mondeo 1.8LX - P/X'ed
2002 02 Ford Focus 1.6 Zetec w/ Climate Pack!
AppleSei is offline
Old 25-03-2008   #5
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: gear knob
You don't actually need the OMP bit.
I have an alloy (gear) knob and I made my own adaptor. The knob doesn't have to move, the sleeve does, and the knob is large enough to hold the sleeve in place.
So, lop the appropriate amount off the top of the sleeve to allow the new knob to fit, and when you want reverse, don't use the knob, use the sleeve.
Lots of knob talk here!!!!!!!!!!!!
D
rallycinq is offline
Old 25-03-2008   #6
Brooky's Avatar
Trader Rating: (1)
Re: gear knob
D
I have an adaptor and currently doing nitranes conversion. How does having the sleeve not attached to the nob affect auto testing David?? as i will be looking into that kind of competition when mines done.....and the only autotesting ive seen they were reversing for about half the course.
16v cinq with ITB's
Brooky is offline
Old 26-03-2008   #7
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: gear knob
it wouldnt matter but i would make sure its chunky for your hand grip.
i had an aftermarket gearknob on the NA cinq and all i did was leave a gap below the gearknob base with a cable tie to spce it.
i then just manually pushed the gearshaft assembly down to select reverse
custard is offline
Old 26-03-2008   #8
rallycinq's Avatar
Trader Rating: (1)
Re: gear knob
I put an additional knob under the alloy knob. Its a little bit fatter and is easy to get at when reversing required. Remember mine is a six speed so the gaps between the gear selectors are quite small.
D
(G) gear knob lakey88 Uno 17 22-03-2007 22:00
(S) gear knob distortionrockets Uno 13 01-05-2006 12:40
(S) Gear knob angel751 Punto 7 07-05-2005 15:14
(S) Gear Knob CinquePunto Cinquecento / Seicento 6 08-10-2004 09:16
(S) 55 S gear knob SOS017 Punto 2 28-06-2004 01:25
