The FIAT Forum
Old 25-04-2007   #1
BravoBucket
kayl0rz's Avatar
Trader Rating: (0)
kayl0rz has donated! United Kingdom
lowering a sei
i know nothing.. remember this..
whats the recomended lowering for a sei sporting? shes standard and the wheels are standard too.. 14" i believe? or i might be wrong.. whatever.. they're standard lol.. how low can she go before she scrapes on the floor all the time and sets herself on fire from the sparks?
oh and also.. how do you do it? =D a shopping list of what i need would be nice too..
id love to do all the work on my car myself.. but unfortunatly i dunno how.. so for that to work.. people need to tell me lol. i know as soon as i know.. i can do it!
fankooo!
kayl0rz is offline
Old 25-04-2007   #2
Trader Rating: (0)
Tabblink182 has donated! United Kingdom
Re: lowering a sei
I would say check one of custards FAQ's
but there is none on lowering
well you need a set of lowering springs either 20, 40 or 60mm drop and to fit them is basically a peice of piss
you will need
-socket set
-jack
-axel stands
-spring compression tool (can do it without but very hard and not recomended from persanol experiance)
there are 3 bolts i think on each strut in the engine bay
then is a matter of taking the bottom of the suspension unit off the brake disc hub
once the suspension unit is off dismantle the unit and take the old spring off, put the new one on
and put it all back togather and reverse the process
if u just take the wheel off and have a look its pretty self explanitary
the back is basically the same by princaple
Tabblink182 is offline
Old 25-04-2007   #3
Trader Rating: (0)
Re: lowering a sei
scrap that actually, this explains it alot better
http://www.fiatforum.com/cinquecento...uspension.html
Old 25-04-2007   #4
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
AppleSei has donated! United Kingdom
Re: lowering a sei
You have 13'' wheels as you are just a sporting based on the comments in your sig.
Do you plan to keep original wheels or upgrade in the future?
2001 Modded Sei Sporting - GONE!!
1998 Ford Mondeo 1.8LX - P/X'ed
2002 02 Ford Focus 1.6 Zetec w/ Climate Pack!
AppleSei is offline
Old 25-04-2007   #5
BravoBucket
kayl0rz's Avatar
Trader Rating: (0)
Re: lowering a sei
i dunno.. i'd eventually like some nicer wheels but if i lower.. they cant go much bigger, can they? cos they'll rub on the arches or whatever it is.. i could lower and get some nicer 13".. if there is such a thing.. or could i just buy biiiiig wheels and it'll make it LOOK like its lowered without actually having done anything?!
kayl0rz is offline
Old 25-04-2007   #6
Trader Rating: (0)
Re: lowering a sei
well there is a limit to your plan, cinqs wont go any bigger than 15" without arch mods
id recmend a 14" wheel as its the best comprimise
with a 35mm drop ?
Old 25-04-2007   #7
Scandinavian Passion....
StoneNewt's Avatar
Trader Rating: (0)
StoneNewt has donated! United Kingdom
Re: lowering a sei
a Sei will take 16" rims with 195/40R16 tyres with no mods, besides steering rack limiting which is required at 15" so fair game imo, as long as you don't lower it more than 15mm
Daily Driver: Seicento Sporting, Dark Grey, MPI 1108cc 8v, stock externals
Track Day: Seicento Sporting, Yellow, High Boost 1247cc 8v, Factory Abarth body kit
Luxury Liner: Volvo V70 D5 Sport, Black, chipped & uprated intercooler, V70R body kit
StoneNewt is offline
Old 25-04-2007   #8
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
Re: lowering a sei
The bigger the wheel upgrade the less the drop.
40mm on 14'' and correct spacer/tyre choices will see a nice looker from the outside and a better driving experience and lack of rubbing/scraping etc etc issues for the driver
AppleSei is offline
Old 25-04-2007   #9
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Re: lowering a sei
I don't think there's anything to be gained by going for more than a 40mm drop. And there's really nowt to be gained with an NA Cinq on going larger than 14". The guide above is a great one. For the rears, soak everything in WD40 the day before, put the car up on axle stands at the back (in gear and chock the front wheels), slacken the bolts at the top of the shock (the nuts are welded on, just use a spanner to hold them), put a jack under the spring so it just takes the weight, undo the bottom bolt, let the jack down, and the spring will pop out.
It's worthwhile (shocks have an effective life of 40,000 - 50,000 miles only) replacing them at the same time.
fingers99 is offline
Old 26-04-2007   #10
I Need Beer
allanhelen's Avatar
Trader Rating: (0)
allanhelen has donated! United Kingdom
Re: lowering a sei
To still be a useable car you can't really go lower than 30mm. With that sort of drop you should easily be able to fit 14" wheels in the future if you deceide to.
VAD Hi Boost Turbo Cinq
None Fiats 3.2 V6 Cavalier, Peugeot 206 GTI 180 & JR Supercharged Mk2 Mazda MX5 1.8
allanhelen is offline
(G) how many cento owners custard Cinquecento / Seicento 70 4 Days Ago 21:05
