| Alloys & Brake dust!!! My alloys seem to attract brake dust like mad and it sticks... Is there any wax people can recommend to protect them for a bit longer than them turning black on the first trip after washing? Would normal wax/polish work? Sorry if that sounds a bit dumb but I'm fed up of spending ages cleaning my car & alloys and them being dirty the second I drive anywhere!!
| MG ZR Owner :) | Re: Alloys & Brake dust!!! You must be braking too much then . Thare are alloy cleaning products by the likes of Meguairs etc ( Can't spell it!) that should provide a protective layer on your alloys, but they cannot magically banish brake dust!
| | #3 | |||||
| | #4 | ||
| The modfather | Try using a different type of brake pad one that creates less dust
| | #5 | ||
| ****** | Re: Alloys & Brake dust!!! take your brakes of and get steel plates on your shoes :P well it works for my bmx but with out steel plates lol, just new shoes very often J
__________________ Jonathan Waller ![]() Current: Merc A170 Advantgarde SE, 1987 Jaguar XJ40 Sovereign 3.6 , Mini City 1000 Past: Fiat Panda 1000 Fire (dead), Peugeot 106 Mardi Gras 1.5 D (Now my brothers) | ||
| | #6 | ||
| compensation needed | Re: Alloys & Brake dust!!! i had EBC green stuff pads last time and they were pretty good at not leaving as much dust, this time i have Black diamond, the key word being 'Black' as thats how my wheels are left
| | #7 | |||||
| The modfather |
| | #8 | ||
| compensation needed | Re: Alloys & Brake dust!!! Cheers PNL, and your right, im keeping the grooved and drilled discs but going back to EBC pads after these Black diamond ones have gone
| | #9 | ||
| All Hail the Woodsman | Re: Alloys & Brake dust!!! I normally use a standard carwash product with an alloy wheel brush follow up with a polish, I've been using Autoglym Super Resin Polish because I've got a 500ml bottle. Any polish followed by a wax would do. Does make cleaning easier and helps prevent damage.
__________________ Fiat Bravo T-Jet Sport / Strada 130TC (currently undergoing restoration) www.strada130.com | ||
| | #10 | ||
| Re: Alloys & Brake dust!!! Try Supawheels Protector, available from Supagard. This spray on resin will last for around 3 months per application. When it starts to wear off, simply use the supawheels cleaner, then re-apply the protector again. About a years supply with the kit, which normally costs abot £24.95. website address is www.supagard.com
| | #11 | ||
| Re: Alloys & Brake dust!!! You can get a product called "Wheel Wax" not sure how good it is I've never used it. I tend to use a non-acid based cleaner (acid based will eat at your laquer if you're not carefull) then use what ever wax I have lying around. I've found brake dust washes off really easily this way. Be careful if you use a spray tyre dresser too as the residue will attract the brake dust. I rub my tyre dresser in and clean the wheel after.
__________________ Fitted: Supersprint backbox, decat pipe, Blitz Dual Drive Blow Off Valve, Gtech chip, BMC panel filter and modded air box, 3G 20 Groove front discs, Dash rings, clock ring, speaker rings, heater rings and gear frame. Eibach lowering springs, Full LE bodykit.Dark wheels, calipers and fuel cap! | |||
| | #12 | ||
| Re: Alloys & Brake dust!!! A few products around, try the link below
| | #13 | ||
| HI all this is my first post and i had a problem whith dust on the front wheels and i found a cheap product that has done the job every time i use it is called CARPLAN WONDER WHEELS.(nothing to do with shela's wheels lol).and it a 6 times winner in the best buy catagory on auto express. it works and you get the brush with it but this can only be used on original wheels (wheels that have not been sprayed at home or laqured at home) and before i tried this i had tried other procucts and what have you but this works a treat and its cheap just £5 a bottle (1ltr)..i normaly do not endorse any product but this works for me and my wheels were well ""black"" ..you need gloves when using this stuf as it makes your hads ich like hell..but bloody good stuff and made my wheels look brand new again and again...found in boyes and other auto shops....and no i do now own the company..lol i am not victor kyam...and it last for about 10 uses out of one bottle as your first application stays good for ages..i recomend you given them a quick wash down before starting with water then apply the product with the brush then leave for 5 mins then hose off with water....done and dusted....PS..the pic shows 2 boxes of wonder whels as if you live near MACRO you can get 2 for just £7.50....so save even more....god i sound like a housewife..lol
Last edited by puntoinfronto; 06-06-2006 at 11:06. Reason: ad more info and correct typo's | |||
| | #14 | ||
| Re: Alloys & Brake dust!!! Your better off protecting them and applying a sealent to alloys, and wash them with car shampoo. The sealent repels dust and comes away easily when washing.Lots of products out there, here is one of them http://www.cleanyourcar.co.uk/shop/w...alant/p_9.html
| | #15 | ||
| Re: Alloys & Brake dust!!! I used to use wonder wheels then found out that it is acid based so stopped using it as eventually it will eat away at your laquer especially if you don't wash all of it off. Good bit of info puntoinfronto but I wouldn't touch it personally. I just clean my wheels every week so as not to let the brake dust build up and if washing the inside I'll use a non-acid based product. Most times I just use auto-glym car shampoo. Dave
| | cruisestoke | Cinquecento / Seicento | 2 | 01-10-2004 13:31 |
| | Shakey | Cinquecento / Seicento | 2 | 22-09-2004 10:50 |
| | Q TOY | Bravo / Brava | 1 | 13-03-2004 03:43 |
