| Sei: Paraflu or any antifreeze? Is Paraflu essential or does any antifreeze do for the coolant? Thank you
| i am | Re: Sei: Paraflu or any antifreeze? any quality antifreeze at the correct dilution | ||
| | #3 | ||
| Re: Sei: Paraflu or any antifreeze? so 50:50 antifreeze & distilled water you mean. This will be the same as Paraflu eqvilent (spelling)? thanks
| | #4 | ||
| i am | Re: Sei: Paraflu or any antifreeze? no need for distilled water in the cooling system and dilute as per the pack instructions. you will have no problems | ||
| | #5 | ||
| Re: Sei: Paraflu or any antifreeze? cool, that's answered my question. How do you drain the old coolant out the bottle? in order to put the new stuff in? Thanks again
| | #6 | ||
| i am | Re: Sei: Paraflu or any antifreeze? remove the lowest coolant pipe. best to get yourself a haynes manual though | ||
| | #7 | ||
| Re: Sei: Paraflu or any antifreeze? could you just quickly explain thanks
| | #8 | ||
| i am | Re: Sei: Paraflu or any antifreeze? well what can i say.disconnect the lowest coolant hose to let the coolant run out. | ||
| | #9 | ||
| Re: Sei: Paraflu or any antifreeze? is that the one with the butterfly clip that comes out of the wing area?
| | #10 | ||
| i am | Re: Sei: Paraflu or any antifreeze? one over the gearbox/engine join | ||
| | #11 | ||
| Re: Sei: Paraflu or any antifreeze? sorry, really don't know what you're about. I thought it was that hose that comes out the wing area? surely
| | #12 | |||
| The Thrill of Driving.... | Re: Sei: Paraflu or any antifreeze?
I use a big bottle of cheap drinking water from ASDA 5L for about £2.50 job done, all the cars I have done this to have run cooler and heated up quicker after a good heavy duty coolant systems flush and change with new anti-freeze. Aaron.
__________________ ![]() 1992 Lancia integrale EVO1; 1995 Toyota Celica GT4 ST205; 2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's) | |||
| | #13 | |||
| | #14 | |||
| | #15 | ||
| Re: Sei: Paraflu or any antifreeze? If you look under the bumper you will see the radiator on the drivers side. The hose you want to pull of is the one coming off the bottom of the radiator - it might be difficult to shift, so try twisting it while pulling very hard!
__________________ 1998 Fiat Coupe 20vT 1989 Lancia Y10 GTie | |||
| | shay | Punto | 4 | 14-08-2005 17:00 |
| black sei sporting in fairfield (south wales)? my sei sticker on boot | benfredjosh | Spotted / Was It You? | 0 | 23-05-2005 11:52 |
| | deeqsei | Cinquecento / Seicento | 2 | 10-02-2005 20:02 |
| | jebs | Cinquecento / Seicento | 16 | 02-12-2004 23:58 |
| | fordy | Cinquecento / Seicento | 5 | 12-07-2004 19:49 |
