Please help. Break lights not working changed off side light unit after discovering the original had filled up with water and corrosion.Still not working so changed bulbs, fuse and checked earth connection that's fine can't find any splits in wires leading up to the break lights. So can only be the switch under the break pedal or a wire loom problem. Can any one help?
