I was once told ,double the rim size and add 2 psi and you'll be close enough
NO...!!
5.5J x 2 + 2 = 24
24PSI.. are you a rim refurb specialist trying to drum-up trade
Would I then be wrong in thinking if mine was say, 2.2bar on standard 14inch wheels, and then I moved to 15 inch with wider lower profile tyres, the pressure should be different? I assumed regardless of the tyres it would be the same?
I've pretty much just stuck to 32 PSI all round, on all my cars. What's 1 or 2 PSI between friends?
You would need to check the handbook, there could easily be a couple of psi difference
Well my wheels don't feature in the handbook at all!
What size are your tyres and model/engine of your car
I'll check my handbook agian now, because this is going to be embarassing if it is in there (when i can find it).
It's a 1.2 Fiat 500 '10. Tyres are 195/50 R 15.
Did you change the tyre size from original, because your right they don't seem to be listed.
i would use 2.2 front and 2.1 bar rear. Thats 32psi and 31psi for normal weight load,
but that is just best advice not official
