Lamps by Post - For all your lighting needs
Thread Tools
Old 14-05-2014   #1
Headlight Restoration
After researching tricks of the trade tried the toothpaste method which initially seemed to work before the plastic covers clouded over again.
Since buying my 03 Punto Sporting a month ago haven't been able to drive it at night.
I've just had a guy called Steve from Auto Brights come out and in an hour had them all sorted. If you're fortunate enough to live in Sussex/ Kent then give him a call- you will find him via Google.
comcraft is offline Reply With Quote Quote
Old 14-05-2014   #2
varesecrazy has donated!
Re: Headlight Restoration
there was a very similar thred (with pics) of a punto 2B last week,
that outfit were portsmouth based,
as so many modern cars have plastic covers/ lenses,
there are probably repair companies in MOST areas,
was it @ 30 per lamp..??,
Charlie - Oxford
Old 16-05-2014   #3
I always find normal car polish sorts mine out, I haven't though had any that where really bad, glad you found someone to do them properly!
2010 Campovolo Grey Abarth 500, red leather, Skydome, Climate.
griff74 is offline Reply With Quote Quote
Old 17-05-2016   #4
USA
3M makes restoration kits for headlights. They work great!
sgRob is offline Reply With Quote Quote
Old 08-07-2016   #5
i use g3 compound polish when moping car after painting if head lights a bit dull i run mop over with g3 and badges sometimes
bumble1982 is offline Reply With Quote Quote
Old 11-07-2016   #6
Trader Rating: 1
Plastic headlight "restoration" depends on the type of corrosion. If it's UV deterioration than you can polish it up but be sure to get some protective film on there as it only temporary and you'll need to do it every few months. If it's lack of cleaning, acid bug spatter and pollution you can clean it and use wet and dry to get a key before evening it out with a head gun. Again use a protective film after.
Liquid Knight is offline Reply With Quote Quote
Old 20-08-2016   #7
Trader Rating: 1
petercresswell has donated!
petercresswell is an honorary friend of the forum :)
I had yellow opaque lamps on my daughters Micra. Chrome polish from Halfords and my rotary polisher had them both back to sparklling bright in about 1 hour for about 3. I would NOT want to do this polishing by hand though!
petercresswell is offline Reply With Quote Quote
Old 24-08-2016   #8
Moderator
Peter Pick-Up's Avatar
Peter Pick-Up has donated!
Netherlands
Peter Pick-Up is offline Reply With Quote Quote
Old 04-01-2017   #9
coxy1892 has donated!
Bit of old thread but hey ho
Just used auto glym kit on the wifes crv. Absolutely brilliant kit. Headlights look brand new and they where pretty bad before
coxy1892 is offline Reply With Quote Quote
Old 04-04-2017   #10
United Arab Emirates
Headlight available at economical price on truckcare dot com
pankajkumar is offline Reply With Quote Quote
Old 28-04-2017   #11
I had really bad headlights on my old Astra, it got a warning on the MOT. I used the Turtle wax kit which I got off eBay for about 10. I would say there was a 35-40% improvement
Robpo is offline Reply With Quote Quote
Old 12-05-2017   #12
Flat them back with 1500/2000 grit wet and dry ,then coarse compound working up to fine finishing with a Uv resistant seal
dan dan the pandaman is offline Reply With Quote Quote
Thread Tools
(S) Headlight Restoration Puntomk284 Punto (Mk2/2b) 2 15-04-2014 23:54
(G) Headlight restoration tbrads94 Punto (Mk2/2b) 15 20-09-2013 13:51
Headlight Restoration Kits? BradThomas Car Care 7 16-07-2013 23:20
Headlight restoration Brin Bodyshop 40 23-04-2010 22:02
