| | Thread Tools | Search this Thread |
| | #16 | ||
Posts: 14,567 Thanks: 713 Trader Rating: 0 | Re: Body Shield Pro No not just from water, when you then dry it and push it all into the paint even if your using a plush drying towel.
| | Quote
| | #17 |
| | Re: Body Shield Pro as Matt says some containments such as metal dust (from brakes/ railway lines) industrial fall out will lightly bond to the car on contact (ether chemically or by penetrating the outer layer of paint slightly) rinsing alone will not remove them then when you pass your drying towel or shammy over you will drag it over the paint....... using a decent shampoo will have suitable surfactants to help remove and loosen the substances, have lubricating property to prevent them from doing too much damage once dislodged with a light passing over with a wash mitt or suitable detailing sponge |
| | Quote
| | #18 | ||
Posts: 387 Thanks: 23 Trader Rating: 0 | Re: Body Shield Pro Good to know ta, there was me thinking I'd found a way to save some time over the summer, ha
| | Quote
| | #19 |
| | Re: Body Shield Pro ha ha no such thing as a free lunch ![]() one of the best investments i made was a foam lance to go on the pressure washer even though it doesn't remove everything http://www.detailingworld.co.uk/foru...mber+auto+foam |
| | Quote
| | #20 | ||
Posts: 387 Thanks: 23 Trader Rating: 0 | Re: Body Shield Pro ha ha no such thing as a free lunch ![]() one of the best investments i made was a foam lance to go on the pressure washer even though it doesn't remove everything http://www.detailingworld.co.uk/foru...mber+auto+foam
| | Quote
| | #21 |
| | Re: Body Shield Pro Too true and yeah, a pressure washer and snow foam is next on my list when I free some funds up, all the dust on the car while it's dry is doing my head in! I did a full detail on my car a few days ago and it was covered in dust inside a 5 mile trip. The OCD is not having fun at the minute! ![]() take a look at this http://www.argos.co.uk/static/Produc...7C14418805.htm http://www.argos.co.uk/static/Produc...7C14418805.htm granted there are better quality machinines but here is the catch pay the extra £10 - £12 for the extended you bust it we will give you a new one 3 years peace of mind ![]() then this http://shop.autobritedirect.co.uk/au...ions-338-p.asp the above washers use the kew alto fitting
__________________ What Goes Up Must Come Down..... Last edited by Andy Monty; 02-05-2011 at 19:47. |
| | Quote
| | #22 | ||
Posts: 800 Thanks: 30 Trader Rating: 1 | Re: Body Shield Pro Good stuff, thanks for the info
| | Quote
| | #23 | ||
Posts: 123 Thanks: 3 Trader Rating: 0 | Re: Body Shield Pro take a look at this http://www.argos.co.uk/static/Produc...7C14418805.htm http://www.argos.co.uk/static/Produc...7C14418805.htm granted there are better quality machinines but here is the catch pay the extra £10 - £12 for the extended you bust it we will give you a new one 3 years peace of mind ![]() then this http://shop.autobritedirect.co.uk/au...ions-338-p.asp the above washers use the kew alto fitting Also what foam are you using is it Bilt-Hamber Auto Foam? Thanks in advance for help.
| | Quote
| | #25 | ||
Posts: 30 Thanks: 0 Trader Rating: 0 | Re: Body Shield Pro Just whenever the paint feels rough again, there's no time limit on it Personally, I wouldn't touch something like this. Not because of what the products are made with or whatever, just that if you clay, polish and wax properly it will last for at least 2 months even with a crap wax. ![]() ![]() Ok what products do I buy then for doing this
| | Quote
| | wayne695 | Ducato | 1 | 18-03-2008 19:53 |
| charity shield | st-hamuel | Leisure Lounge | 0 | 03-08-2007 20:12 |
| | gazman | Punto (Mk2/2b) | 11 | 07-10-2006 02:10 |
| | mark m | Barchetta | 5 | 04-04-2006 16:04 |
| | Genie | Punto (Mk2/2b) | 8 | 06-07-2004 00:47 |
