The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > Car Care
Old 16-07-2008   #1
Trader Rating: (0)
wax polish??????
newbie here
getting a black punto end of the week and want to keep it clean.
i have had a black samrt roadster coupe which was a nightmare to keep clean as was so low to ground etc...
i know about using 2 buckets...lambswool mitt ... microfibre cloth to dry etc...
from what i can gather- polish strips the imperfections in paintwork and the wax then seals and protects the paintwork
i have some autoglym super resin polish-
how often should i use the super resin polish?
and should i use a wax to protect the paintwork after using super resin polish?
should i re-apply the wax if so how often?
pea69 is offline
Old 17-07-2008   #2
Mark Elvin's Avatar
Trader Rating: (0)
Re: wax polish??????
SRP is a fairly good all in one product (although I hate the way it leaves white marks), I'd follow it with a Dodo Juice wax.
The Detail Doctor.
Mark Elvin is offline
Old 17-07-2008   #3
Andy Monty's Avatar
Trader Rating: (0)
Andy Monty has donated! United Kingdom
SRP is a good polish for moderately deteriorated paint work it wont deal with deep swirl marks however it will mask them...
it depends what you want to do
for a Quick tart up Autoglyms Ultra deep shine is an all in one designed for dark cars and contains more fillers than SRP however that's not going to cure the problem permanently....
for that will take a bit of work, care and time (along with a sore arm)
your best off starting with a clean car give it a wash with All Purpose cleaner this should remove any wax/polish
next clay the car with a clay bar (search the car care section for how)
Next give each panel a good going over with a scratch removing compound such as Meguires Scratch-X or T_cut METALLIC
next polish with Super resin polish
then seal with a wax or synthetic sealent such as Extra Gloss Protection
Andy Monty is online now
The following user says "Thank You!" to Andy Monty for this useful post:
james_f (2 Weeks Ago)
vB code is On
Autoglym Radiant Wax Polish dt900 Car Care 4 30-03-2008 17:11
Difference between wax and polish? FIA786 Car Care 12 10-01-2008 22:51
punto mk2 - wax/polish/other? lottie_ Car Care 5 26-06-2007 12:28
Harly Wax - Yellow Brazilian Carnauba Wax J333EVO Car Care 31 18-09-2006 07:46
wax on .... wax off sammiboo Car Care 10 11-07-2005 10:29
