| | #16 | ||
| TJet powaaaaaaa | Re: Finally Plucked Up The Courage...... Do you not have any before pics?
| | #17 | ||
| Re: Finally Plucked Up The Courage...... What methods did you use to eradicate your RDS's
__________________ for traders advertising rates to place an add in your signature please contact use the "contact us" link in the footer | |||
| | #18 | ||
| Re: Finally Plucked Up The Courage...... After I had checked the clercoat thickness I used some 2500 grit wet & dry, followed by 3000 grit, wetting all the time using a mixture of Megs Shampoo Plus & water to aid lubricity. Then a session with the Cylco in the normal manner & all of the RDS had gone.
__________________ The Detail Doctor. Last edited by Mark Elvin; 17-07-2008 at 10:32. | |||
| | #19 | ||
| Here to help | Re: Finally Plucked Up The Courage...... you can safely go as coarse as 1500 grit on lacquer. ![]() I finish lacquer after I've sprayed it with a 1500 dry orbital sander. I follow with a 2000wet and dry and then compound with a buffer. the shine left is ![]() sometimes I use a 3000 as well before buffing though. Dont try this at home, if you dont know what you are doing though. ![]() I am currently experimenting to see if its possible to use a 400 dry grit on lacquer and be able to give the lacquer a shine by then using 800, 1000, 1200, 1500 wet n dry finishing with a buffer.
__________________ Bravo HGT 306 HDi sport Coupe 20VT | ||
| | #20 | ||
| Here to help | Re: Finally Plucked Up The Courage...... Oooooops, forgot to say. Awesome work Mark seem to have a few top class auto detailers on this forum now.
| | #21 | ||
__________________ The Detail Doctor. | |||
| its finally getting to me | sammiboo | Leisure Lounge | 195 | 16-06-2008 20:48 |
| | RichC | Grande Punto | 1 | 16-12-2006 12:13 |
| finally... | Jai | Leisure Lounge | 9 | 24-07-2006 23:20 |
| Finally got it/ what ya up to | Nyx | Leisure Lounge | 25 | 16-06-2006 21:57 |
