| T-Cut caused faded paint Hi, My wife managed to scratch our new 57 Bravo with her ring. Therefore my first reaction was to go for the good old T-Cut which in the past has never let me down. However, a day after applying the T-Cut the 2 inches of paint around the scratch faded and in certain light you can see that the paint is slightly duller. Any ideas on how to fix this? Is there a polish or gloss application that can bring back the finish? Thanks, GazzaS
| meow | Re: T-Cut caused faded paint was it normal t-cut? if so id try some metalic t-cut then some wax.
__________________ PUNTO JTD ![]() | ||
| | #4 | ||
| Dislikeskeyboardwarriors | Re: T-Cut caused faded paint use a conventional wax... simonize yellow tin and work it for a few mins.. leave to dry and buff... keep doing it... it will buff up..... ive used autosol on paintwork before and thats a harsh abrasive 4-5 coats of wax brought it back no problem... but as dave mentioned steer away from t-cut as its only really meant to recover oxidised paintwork..
__________________ | ||
| | #5 | ||
| Nightshift! Awesome! :( | Re: T-Cut caused faded paint Tcut is an aggressive polish. All that has happened is that the clearcoat on your paint has become hazed. This is easily fixed by using a much softer polish. Waxes just sit on top of the paint. A polish will smooth out the surface of the clearcoat making it clear again. Then if you want to wax it, you will help protect the paint aswell. | ||
| | #6 | ||
| taffy git | Re: T-Cut caused faded paint
__________________ Events Calendar Sunday 10th August Mitcar Sunday 7th September Trax Sunday 14th September Gaydon 19th-22nd September Butlins Skegness Weekender | ||
| | #7 | ||
| Re: T-Cut caused faded paint T-cut is fine on older 1 stage paints but on modern clear coats its a serious No No (although the metallic t-cut is ideal for prepping panels for stick on rubbing strips and decals if my experience is anything to go by) as for a correction of the damage you did (well we can blame your wife in the first instance ) is as said above to use a finer polish. I would try Meguires scratch Xhttp://www.elitecarcare.co.uk/produc...products_id=35 ![]() apply with one of these.. http://www.elitecarcare.co.uk/produc...roducts_id=382 its what is referred to as a Diminishable abrasive compound the more you work it in the more the "grit" brakes down finer and finer you keep rubbing it until you are left with just an oily film how to use it... then finish with a polish say autoglym super resin polish then top it off with a coat of wax hope that helps
__________________ What Goes Up Must Come Down..... | |||
| | #8 | ||
| Re: T-Cut caused faded paint Hi Everyone, Thanks for the great advice It was normal T-Cut I used on the Metallic Black Bravo Paint (egg shell effect).So to sum up, I should: 1) Purchase a finer polish and work into the area 2) Apply a good wax and buff the area Thanks, GazzaS
| | #9 | ||
| Re: T-Cut caused faded paint i'm glad i read this post, was considering T Cut for some light scratches. hope it works out with your Bravo.
__________________ ![]() French Connection(s) to Italian Job | |||
| | #10 | ||
| Re: T-Cut caused faded paint ive bought the yellow carplan t-cut colour fast solution and was wondering if it will brighten up my paintwork..i was confident but now im abit worried...its for my yellow punto but i dont want to use it if its going to spoil the paintwork...i mainly got it because when i first bought it the deler scraped the rear wheel arch so fixed it and it looks so much brighter..i want the whole car to look the same colour
| | #11 | ||
| Re: T-Cut caused faded paint Sam i wouldn't waste your effort on the Colour magic type polishes/cleaner/wax's as soon as it rains it begins to wash off and look patchy if you bought it from halfords take it back ask for a refund/exchange (as your mum picked the wrong stuff up ) or e-bay itthen buy a bottle of Autoglym Super resin polish work this in well to the paint using a foam pad and it should remove the layer of oxidization thats causing it to look faded....
| | #12 | ||
| Re: T-Cut caused faded paint thanks for the advise andy its realy helpfull...ive just gota wait for some good weather and then i can get it looking like new again ![]()
| look what venomco caused | Mikeee | Leisure Lounge | 4 | 13-04-2008 13:52 |
| Could a pothole have caused this? | Dobby | Leisure Lounge | 11 | 19-01-2008 00:18 |
| faded red paint | beau | Car Care | 21 | 12-07-2006 12:13 |
| No heat can be caused by? | redfairy | Punto > Technical | 3 | 29-04-2006 23:01 |
| faded paint work looks pinky | scotty | Lets Talk FIAT | 13 | 24-02-2005 20:49 |
