The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > Car Care
Old 28-03-2008   #1
Trader Rating: (0)
Problem with windscreen washers
I've got a problem with my windscreen washers (front and rear) at the moment. When I try to use them nothing happens! I can hear a noise (like they're trying to work), and until recently some of the washer fluid did leak out from the side of the bonnet only.
I'm guessing that there's a problem somewhere in the tubing - but because the rear washers aren't working either, could this be a big (and expensive) problem??
Anyone got any ideas on what it is or how much its going to cost to fix?
mym72 is offline
Old 28-03-2008   #2
Andy Monty's Avatar
Trader Rating: (0)
Andy Monty has donated! United Kingdom
Re: Problem with windscreen washers
what car MYM?
could be only a few things since both arnt working,,,,
can you get to the pump?
if so remove it (depending on fitments) they either side onto a spigot or pull off at 90 degrees to the bottle in either case there is a rubber diaphragm/ seal this often incorporates a filter made of perforated rubber take this out and clean it there is often a build up if you have used something like washing up liquid as opposed to proper screen wash... once clean try again....
if water comes out problem solved if not
remove the pipes that are connected to the pump and try the screen wash again and have a friend to see if water fires out (make a note of the pipes location) if it doesn't work still
its the valve in the pump that needs either cleaning or buy a new pump (halfords stock the most common ones)
if water comes out with the pipes off check the jets for blockages with a pin and check the hoses arnt kinked/ broken/ or fallen off the jets..
Andy Monty is online now
Old 29-03-2008   #3
Trader Rating: (0)
I had a prob the front ones on my Punto when I got it last year. Dunno if your motor is a Punto, but here goes anyway!!
You can see the 2 pumps under the bonnet going to the washers, I took these away from the wipers, and straightened any kinks in the hoses and checked the jets with a pin/needle to make sure mud or dust hadnt clogged it. Was sorted in about 10 mins. If there are kinks in the pumps you might have to be patient to get a full blast of water... depends how the cable sits and if it keeps getting that kink!!
It'd investigate at Halfords like Andy Monty suggested, even for a wee bit of advice, they might've seen the problem before.
vikerina19 is offline
Old 29-03-2008   #4
Trader Rating: (0)
Thanks for the advice. And forgot to say before - my car's a Brava.
mym72 is offline
Windscreen washers jasond Multipla 0 11-02-2007 13:52
windscreen washers chris1956 Coupe 0 16-12-2005 14:23
Windscreen Washers poggy Ulysse 14 01-02-2005 05:53
(T) Windscreen washers MI DISPIACE Cinquecento / Seicento 9 25-03-2004 14:42
(T) windscreen washers puntopaul Punto 4 30-11-2003 19:10
