| Hi there. I have owned my MkII Punto since 2002, and have covered 30000 miles in it; however last weekend it developed its first issue. While using the wipers last weekend, they decided to ignore the settings I chose. Generally, if I select the slow setting then they run slow for a while, before deciding to switch to constant. If I use the single sweep function, it works most of the time, however sometimes decides to operate continuously for several more sweeps. Additionally, they are failing to stop when I turn them off, usually for about 2-3 minutes. Commonly they are not returning to the stowed position either, just stopping dead in the middle of the screen. Is this a problem that is reasonably easy to fix, or would I be better taking it to an auto-electrician for a check in case it leads to any other issues? Thanks for any assitance Martin
| Shropshire UK | Re: Wiper Issues Check for dry joints on the soldering inside the wiper motor/connections box under the bonnet, I have done this and had success with this fault on 3 occasions.
| | #3 | ||
| Re: Wiper Issues Thanks for the rapid response - however I can't seem to get to the electrics. The cover for the motor etc is secured to one of the wiper connectors, and I cannot remove it. Is it a task for brute force, or is there something else I need to remove? Thanks
| | #4 | ||
| ^^^^^^ | Re: Wiper Issues Hi mate, WELCOME TO THE FORUM!! Have a go at this: http://www.fiatforum.com/punto-guide...en-wipers.html The black plastic over just pops off. Its only clipped on at the back. It may help to remove 2 of the screws from the plastic bit of trim at the bottom of the windscreen. (the screw on the far left hand side and middle). Hope that helps, Alan
__________________ ![]() Punto 1.9 JTD, Punto 1.3 Multijet, Bravo T-Jet 150 Sport, Impreza STi PPP | ||
| | #5 | ||
| Re: Wiper Issues Thanks; that explains it nicely!
| Tags |
| wipers |
| Rear Wiper | ivantate | Panda (New) | 1 | 06-01-2008 18:36 |
| | Lolita | Cinquecento / Seicento | 1 | 30-03-2007 18:57 |
| | chuck | Bravo / Brava | 0 | 28-04-2005 19:06 |
| | grantseicento | Cinquecento / Seicento | 5 | 12-10-2004 14:10 |
