| Hi all First post! ![]() Just a quick question, i am a first time punto owner and i have had it for about 2 months now. Just noticed today that the engine coolant was low so i popped into Halfords and picked up some of their own brand coolant/ anti freeze. when i was reading the back, it said that i should drain the coolant completely before adding the halfords one in case they are incompatible. Is this highly likely or is it something that is a 'just in case' kind of thing? btw i own an x reg punto ELX I'd appreciate any help that anyone could give me as im completely useless at car maintenance.
| Grumpy Forum Moderator | Re: Changing Engine Coolant? how low is low? .... just top up with water unless your going to do a full coolant change which means you have to bleed the system etc
| | #3 | ||
| | #4 | ||
| Re: Changing Engine Coolant? clean tap water..... it might be worth seeing if the likes of ATS/Kwickfit are doing there "free" winter checks and have the concentration of the coolant checked.. surely one of the punto owners will be able to recommend the appropriate coolant for your car, http://www.fiatforum.com/punto-guide...ng-system.html
| | #5 | ||
| All Hail the Woodsman | Re: Changing Engine Coolant? You need to avoid mixing the old (blue/green) and new types (red) as they aren't compatible and could cause problems. If you don't know what you're doing then don't and follow T14086 &/or Andy's suggestions.
__________________ Fiat Bravo T-Jet Sport / Strada 130TC (currently undergoing restoration) www.strada130.com | ||
| | #6 | ||
| SNAP! | Re: Changing Engine Coolant?
| | #7 | ||
| Re: Changing Engine Coolant? I've bought blue coolant and there appears to be green/blue coolant already in the car. should i do a 50/50 coolant/water addition or is it too risky?
| | #8 | ||
| Grumpy Forum Moderator | Re: Changing Engine Coolant? northern water is best not that furry southern stuff
| | #9 | ||
| | #10 | ||
| Grumpy Forum Moderator | Re: Changing Engine Coolant? yeah....tea tastes doon south!
| How to fit a 16v Fire engine in a Panda | panda-sport | Panda (Classic) | 55 | 24-09-2008 07:57 |
| | philipreji | Uno | 2 | 31-10-2007 20:34 |
| Is FIAT reccommended engine coolant the best? | kritip | Lets Talk FIAT | 7 | 24-09-2006 12:38 |
| | HornetUK | Stilo | 4 | 12-02-2005 20:38 |
