The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava > Bravo/a > Technical
Old 10-07-2006   #1
Trader Rating: (0)
Starting problem
Hello, I have some wierd starting problem with my 1996 brava 1.6 16v. When the car is hot (after hour or more driving) and when I stop the engine it starts OK, then after 10 minutes wont start, the symptoms are like the battery is empty. If I then wait for 20 minutes it startswith no problem. Does anybody have some idea what is wrong ?
pely is offline
Old 10-07-2006   #2
Trader Rating: (0)
Re: Starting problem
Check the battery voltage with a multimeter when u r car doesnt start. The reading will confirm if it's the battery.
neoseal is offline
Old 10-07-2006   #3
Trader Rating: (0)
This seems to be overly common on the 1.6. Coil pack or Fuel pump or in my case it was both. Coils cost me 39 pump 79 plus VAT. Thats from a local auto elec place. fiat want 90 and 190 at least from them.
blackburnsei is offline
Old 10-07-2006   #4
Trader Rating: (0)
I don't think this is pump, symptoms are like when the battery is flat, engine is not turning or is turning wery slowly.
pely is offline
Old 11-07-2006   #5
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
it sounds as though when the car gets hot the electrical supply to the strater motor is restriced, this would be possible if either the live or earth cables have a lot of corrosion or poor contact, remove, clean and grease both cables at both ends. also do the main earth strap from the engine to chassis.
jug is offline
vB code is On
ulysse starting problem bazal Ulysse 2 10-04-2005 13:14
Problem starting from cold, Brava 1.4 Kuohu Bravo/a > Technical 1 17-03-2005 20:18
Starting problem - start moter related tc34 Bravo/a > Technical 3 13-03-2005 16:44
Starting problem ClamChowder Cinq/Sei > Technical 15 17-03-2004 00:47
Cinq 899cc starting problem. B3buggy Cinq/Sei > Technical 8 16-03-2004 23:59
