| *HELP* Track rod removal Had a bit of an encounter with the kerb in the ice yesterday and it's bent the n/side track rod. Now how the f@*k does it come out! I've managed(eventually!) to get the track rod end out...damn those taper fits...but at the other end, the steering rack end there's a ball and socket joint. Anyone know how to get this apart? I want to see if it's possible to straighten it slightly then reset the tracking, failing that replace it. I rang fiat, and the track rod is available as a spare part(@ £45!) so it must come out somehow? Does the track rod come with this joint already installed and i have to fit it at the rack? HEEEEEEELLLLLLLLP!
| Hi and welcome to the forum:D If you look along from the ball and socket joint towards the bellows you will see that there is a lock nut and a threaded bar. You loosen the lock nut and then unscrew the ball joint assembly off the tie rod. Count the number of turns so you don't change your tracking. Fix the bend and then screw it back on counting the turns again. If you get a new one and fit that by counting the turns you should have the same tracking again. .....Oh you would still be advised to get the tracking checked again at some point:)..... Dave. :) Marea HLX 2.0 20v <h6>FIATcentral window sticker, silver poppy coral, titanium tax disc. :)Blue Momo Tomahawk Gear Knob :) Blue gaiters, Blue sidelights, Blue interior lights, Blue lacquer on engine, feeling blue ;) Ecotek fitted, removed and waiting for warm weather So much to do, so little time.... and Totally Skint!! :(</h6>
| For Turbo owners: Track control arm clamps! | Morty Mort | Uno | 6 | 19-08-2004 16:03 |
| Track rod end | arseofbox | Cinq/Sei > Technical | 18 | 22-07-2004 21:20 |
| Track Car | James M | Leisure Lounge | 2 | 28-01-2004 21:57 |
| CCC Track day report | CentoEvo | Events | 4 | 30-04-2003 16:52 |
| 15th June Track Day | 2.0 20v | Events | 0 | 07-06-2002 18:02 |
