The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 23-08-2008   #1
Trader Rating: (0)
Bravo 1.6 idles high
I just bought underprice bravo mk1 1.6, which has idle problem. It idles high . When starting revs hold 1500 and then when going out of parking place revs hold 2000 and it stays at 2000 at least 5minuts. When hot revs are from 1200 to 800. When I drive and press clutch and cut of throttle revs holds at 1200 mostly. Last owner has replaced new idle control valve and coolant temperature sensor. I also noticed that brake pedal is high and falls a little when revs fall to 800. I also clean butterfly valve and changed spark plugs and filters.
Is it injector fault or damaged ECU?? I also looked for air leak, but pipes are seen ok. Is there any special way to check for a leak?
fiat37 is offline
Old 25-08-2008   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
Re: Bravo 1.6 idles high
you really need to check very carefully for a leak on the intake including the intake manifold.
the brake pedal behaviour is not unusual and caused by the change in vacuum that the brake servo is experiencing while the idle is erratic.
i doubt it is an injector fault, but you can do a quick test to measure their resistances using the wiring connector at the right hand end of the fuel rail. centre pin is earth, other 4 pins are for the injectors. each injector should have approx 16ohms, any with less than 13ohms i would replace.
jug is offline
Old 25-10-2008   #3
Trader Rating: (0)
unfortunately i did not find any leaks. I listened engine carefully, too. I noticed sound from MAP sensor when revs goes higher, so more air must be in. If it iss't leak, ECU in opening idle valve. I noticed that the car has most problems with temp around 20 degrees C. Now in cold weather car starts at 1500rpm and stalling first 15second (if i press throttle more it ussualy helps). Than it runs quite ok but after 1min (i assume temp. is around 20-25) stalling again. Its tricky problem because coolant sensor is new. Is it then air temp. sensor?? Is is possible that hose for MAP sensor is stuck and dirt mobilize when gettnig hot?
fiat37 is offline
Old 27-10-2008   #4
jug
jug's Avatar
Trader Rating: (1)
i would repalce them with scrapyard parts to be sure.
the throttle position sensor is likely so definately replace that.
jug is offline
Tags
idle, injector
(G) Bravo 1.2SX Revving itself, High Idle kickassjay Bravo / Brava 5 21-05-2008 22:33
(T) idles better without the alternator arc Cinquecento / Seicento 8 14-03-2006 00:55
(T) Really High Fuel Consumption (Bravo 1.6) DanBravo1.6 Bravo / Brava 14 20-09-2005 00:30
(G) Bravo/as and High Mileage Steven Bravo / Brava 11 18-09-2005 21:54
