| Need urgent help with speedo please Need urgent help with speedo please. Hello, Im hoping someone out there might be able to help with this. I was driving back home today, quite happily crusing along the motorway, but then the next thing i know my speedo suddenly drops right down to zero and dies! I pulled in at the next service station to see if turning the engine off and starting again would bring it back to life but that didn't work. I had about another 1+1/2 hours drive after that to and it remained dead for the duration. When i turn the key the speedo does move up about a milimeter but just won't seem to work at all. The rest of the dash pannel seems fine, no warning lights, rev counter is fine, backlights, odometer etc. I really need to fix this asap as i can't really use the car with a dead speedo lol. If it helps its a 1999 1.2. If anyone has any ideas i'd be very greatful. Thanks Matt
| blessed are the apostates | Re: Need urgent help with speedo please replace the speedo sender unit on the gearbox | ||
| | #3 | ||
| Re: Need urgent help with speedo please Thanks, is that easy to get to and replace? or does it involve taking other bits out to get to it? Thanks again Matt
| | #4 | ||
| blessed are the apostates | Re: Need urgent help with speedo please it is on the gearbox, you can most easily access it from above and on the 1.2 i dont think you need to reomve anything other than the air intake. it simply screws out of the gearbox after you disconnecting its wiring connector. | ||
| The following user says "Thank You!" to jug for this useful post: | ||
Matt4347 (16-07-2008) | ||
| | #5 | ||
| Re: Need urgent help with speedo please Thanks for that, i've found it now. I've pulled out what i can, which is a plastic L shaped connector bit that the lead was plugged into, and some metal rod thing about an inch long. Are these the bits that i should be replacing or is there more hidden away inside to remove? Thanks again, Matt
| | #6 | ||
| blessed are the apostates | Re: Need urgent help with speedo please that is all you need to replace. | ||
| | #7 | ||
| Re: Need urgent help with speedo please Great, thanks for all your help.
| | Matt4347 | Bravo / Brava | 2 | 15-07-2008 01:06 |
| | bigpigeon2004 | Cinquecento / Seicento | 4 | 08-11-2005 13:30 |
| Tipo Speedo Nightmare - Urgent Help Sought please! | Braundy | Tipo | 0 | 23-08-2005 00:25 |
| | DannyL | Uno | 11 | 29-03-2005 20:19 |
| | dawozere | Cinquecento / Seicento | 2 | 22-10-2004 22:50 |
