| Topping up gearbox oil Bravo HGT Hello forum, Gearbox oil is leaking slightly (A patch about as big as your hand after a couple of days on the drive)....so not a shocking leak but needs to be fixed. Cant get it repaired for a couple of weeks so I want to check the oil levels and top up whilst waiting for the repair to make sure I dont ruin the gearbox in the mean time. I have no idea how to do this!....A few simple instructions would be helpful. Also, what sort of gearbox oil does the car need? Thanks for your help
| blessed are the apostates | Re: Topping up gearbox oil Bravo HGT | ||
| | #3 | ||
| Re: Topping up gearbox oil Bravo HGT Thanks for that. What I really need to know is where the filler plug is actually located. I am assuming under the battery? Any help always appreciated
| | #4 | ||
| blessed are the apostates | Re: Topping up gearbox oil Bravo HGT on the front face of the gearbox (so that means its on the side facing the front bumper, not the top) | ||
| | #5 | ||
| Bravo 155 HGT | Re: Topping up gearbox oil Bravo HGT 12mm hex key!
| | #6 | ||
| Here to help | Re: Topping up gearbox oil Bravo HGT As above. Also, am guessing your leak will be from the driveshaft seal. Easy-ish if it is passenger side driveshaft but if it is from the drivers side driveshaft.
__________________ Bravo HGT Punto Jtd Coupe 20V Coupe 20VT | ||
| | #7 | ||
| faster! FASTER!!! | Re: Topping up gearbox oil Bravo HGT | ||
| | #8 | ||
| Bravo 155 HGT | Re: Topping up gearbox oil Bravo HGT You jack the front up as if you were changing the wheel, or stick it on a pair of ramps, crawl under undo the 12mm hex, get your 1 litre bottle of oil which has a wee straw type thing shove it in the hole and squeeze. Then invert the bottle. Ok so you'll end up overfilling as you can get the car flat.
| | #10 | ||
| Back to petrol for me??? | Re: Topping up gearbox oil Bravo HGT I need to give this a shot because my box feels very clunky and unhappy at the moment.
__________________ 07 Fiat Grande Punto Sporting M-Jet Crossover Black Past Cars 54 Punto Active in Steel Grey, 99 Bravo HGT in Nero Black and 98 Punto GT3 in Broom Yellow | ||
| | #12 | ||
| Back to petrol for me??? | Re: Topping up gearbox oil Bravo HGT Any noticable changes in the way it drives yet mate?
| | #13 | ||
| :) | Re: Topping up gearbox oil Bravo HGT No, but I didn't expect anything. I only checked as I was doing an oil change so thought it worth while. Am a bit surprised that it needed topping up
__________________ Now drives: '52 Megane 1.9dCi ![]() Past: Y-reg Fiat Brava JTD (Pale Blue) (2006) M-reg UNO (2003-2004) '51 Fiat Brava 80 SX (black) (2006) | ||
| | #14 | ||
| Brava 1.6 ELX | Re: Topping up gearbox oil Bravo HGT Will this be the same grade oil throughout the Bravo/a range or will it be different for different models? I need to get some tomrow and top mine up as i have a leak
__________________ | ||
| | sammiboo | Bravo / Brava | 255 | 28-02-2008 23:34 |
