Comment
Guide Tools
<!-- google_ad_section_start -->How to fix the rattle behind the dashboard.<!-- google_ad_section_end -->
Published by Tad-bravo
27-06-2013
Difficulty Level: 1
User Rated:Unrated
Post How to fix the rattle behind the dashboard.
A lot of Bravos have a rattle behind the dashboard so here's a guide on how to fix the most probable cause for this issue. It's a 5 minute job and doesn't require any tools.
1. Inside the engine bay, locate a little removable cover on the right side of the trim covering the lower edge of the windscreen as shown on the pic.
2. Don't try to open it by force or with a screwdriver. Remove the rubber seal from the right so you can slide out the little cover easily.
3. Locate a loose plug inside the empty space as shown on the photo. That's the culprit.
4. Slide your hand slowly, be careful, the black plastic is quite sharp.
5. Grab the plug and pull it out.
6. Hang the plug on the edge of the opening and put the cover back over it.
7. Put the rubber seal back and you're done
(Please let me know if pics don't show.)
Thanks aurick86, austenw90 thanked for this post
Likes zooooom, aurick86 liked this post
Old 27-06-2013   #1
re: How to fix the rattle behind the dashboard.
Excellent
Another option could be to wrap the connector in foam and stick it down with double sided Velcro?
DanTJet is offline Reply With Quote Quote
Old 27-06-2013   #2
Morocco
Re: GUIDE: How to fix the rattle behind the dashboard.
Quote Originally Posted by DanTJet View Post
Excellent
I don't think it's a good idea as that space is for water drainage. anything you add there could just jam it and cause problems.
And why would you look for solutions that are more complicated?
Tad-bravo is offline Reply With Quote Quote
Old 27-06-2013   #3
Isn't that where Fiat put it?
Old 27-06-2013   #4
Morocco
The foam and double sided tape you want to add would come loose with water and then jam the conduit. Not the plug.
The wipers mechanism is also there and could get jammed.
Old 27-06-2013   #5
PANDA!!
Freebo's Avatar
Freebo is part of the official FF Events Team :)
Freebo has donated!
Ghost Ball Champion
Re: How to fix the rattle behind the dashboard.
Nice Guide, please note @Tad-bravo I have moved this to the Bravo guide section and have re-uploaded the pictures as attachments so they don't break in the future
Thanks Tad-bravo thanked for this post
Freebo is offline Reply With Quote Quote
Old 27-06-2013   #6
Morocco
Thanks freebo
Old 23-07-2014   #7
Romania
I am going out right now to try this!
I have been fighting the dashbord rattle for quite some time.
Thank you for the guide!
aurick86 is offline Reply With Quote Quote
Old 07-11-2014   #8
Hi, I have this rattle on my 08 t-jet 150 but inside the space there is no plug. I've checked and doubled checked and it is not there. Is there anything else I can try to stop the rattle?
Thanks in advance, Sean.
seanxtown is offline Reply With Quote Quote
Old 18-05-2015   #9
I had a look and did not see any switch I have a 8 plate bravo
kazrac is offline Reply With Quote Quote
Old 16-04-2017   #10
Cadabena has donated!
Having had a look, I believe this issue only affects LHD Bravos.
Cadabena is offline Reply With Quote Quote
Old 21-04-2017   #11
Netherlands
Couldn't find much about it on the net, does anyone what the plug is actually for?
pmeister is offline Reply With Quote Quote
Old 08-07-2017   #12
**IMPORTANT** When replacing the cover ensure that rain water does not drip down past the join onto the gearbox (test by pouring some water over windscreen and allow to flow through scuttle panel).
I have recently emptied over 4.5 litres of watery oil from my recently bought 1.9jtd 120 5 speed gearbox (it should have 1.7 litres in it).
There is a rubber boot over the gearbox selector shaft which was perished and allowed the water to pass through the grease seal into the gearbox.
After several flushes I have hopefully caught it before any major damage was done to the gearbox but this simple check could save you the cost of a new gearbox.
I dont know if this only affects the 5 speed gearbox.
Brian
Coisty1971 is offline Reply With Quote Quote
Comment
Guide Tools
(G) Rattle when accelerating/idle .... Possible fix. the rake Grande Punto 13 03-10-2013 16:20
(T) Rattle behind the dashboard cinquencento599 Cinquecento / Seicento 2 05-11-2010 16:08
(T) Dashboard rattle Big Black Stilo Bravo 6 30-11-2008 02:52
(G) Dashboard Rattle choppertoo Stilo 19 31-03-2007 18:16
