I bought an ECU plug with wires from a car breaker. I removed the sockets from to connect CC wires to ECU.
Hi,Guys,
The whole process is clear to me. I am only not sure how to connect the CC stick, e.g. which pins from the connector to which cables from the stick?
I have a 1,6 jtd m-jet 105hp.
Thanks for your help!
Hi,Yes please!
I opened once the ECU cable and I think I know how the pins are numbered, it is written with small numbers on the plastic. I tried several combinations but it didn't work.
I was also not sure which from the steering-wheel cables give 5 A electricity, tried with some that give 12 volt, but didn't work.
Did you manage to install it on a 1,6 jtd engine?
Please share how!
Thanks in advance mate!
I did this installation on my 1.6 mjet 90cv Bravo II and the harness was not existing from the ecu to steering-wheel.
Therefore the first step was to create a harness with 4 wires and to pass it through the car from dash board to ecu.
Do you already do it??
Regards
Philippe
(Where are you from ??)
Hi Philippe!
I just want to know how exactly to connect those deam green, yellow, orange, blue and red cables that come out of the stick :bang:. Please help!!!
Thanks!
Salut,Hi again Philippe!
I used the same pin numbers last time, they are still written on my cables! But your technique with the switching on and and following the signal is so simple and yet brilliant, should have thought about it! I just did not know which function to which pin to connect...
I saw that my error last time was that I did not connect the 12v to the Red wire, but to another one...
So again play time this weekend! Yey!
Thank you again mate, I will let you know if it worked!
ps, I speak French mais très mal, seulement quand il n'y a pas autre possibilité
Ciao!
Salut,
Je suis certain que ton cruise control va fonctionner !!
(le mien a marché du 1er coup...)
Philippe
Hi,I also used the information from here: http://www.davole.com/wp-content/uploads/2009/03/fiat-bravo-198-tjet-cruise-control-aftermarket.pdf
If you look at this diagram - on the H007 connector, the 12Volt is not in Nr1 slot, but on Nr2. And on my connector the red cable is in Nr 1...very confusing...
I fugured it out!!! Wohoow! It was one of the other cables that was the 12v+![]()
If you turn the connector from the CC stick, each slot is numbered 1 to 6.
The colors of the cables are as follows: green, yellow, empty, orange, blue and red.
The connections are as follows: Res 38, 12v, empty, On 77, - 78, +56.
I hope this info helps someone!
Cheerz,
Thank you for the clear message. I will try it soon. And If I am successful I will make a Video or Guide with Picture.I fugured it out!!! Wohoow! It was one of the other cables that was the 12v+
Cheerz,
