Tools needed:
  • 6mm hex key
  • size 2 Philips (+) screwdriver (the one included in the tool kit is good enough)
Parts needed:
  • Spare wheel. You can either use another of your road wheel, or a steel wheel. For the sport 225/45R17 I have used a 16" steel Bravo wheel fitted with 195/55R16 tyre.
  • Scissor jack and tool kit. Mine is from an Alfa 156. That is the same as fitted to Stilo and Marea. I would guess this means you could use one from a Bravo/Brava and probably the Alfa 147 too.
