| bravo wheel bearing problem! well basically my wheel bearing will go i will have it professionally changed and less than a month later it will badly go what could be causing it to go like this ??? please help
| Site Sub Admin | Re: bravo wheel bearing problem! did you buy a cheap one?
__________________ RIP Coupe Former owner of 94 punto 55s, 96 bravo 1.6 sx (RIP) & 96 bravo 1.6sx Currently drives 98 bravo 1.6sx. Had use of 97 fiat coupe 20vt and drives His 2006 Panda sporting multijet Shop question? Order question see this thread Other than that - PM me | ||
| | #4 | ||
| Re: bravo wheel bearing problem! no it wernt cheap ones i mmade sure that with the garage and the wheels have been balanced :S:S
| | #6 | ||
| Bravo 155 HGT | Re: bravo wheel bearing problem! Tracking done recently? You can get a free check as if its bad wheels could be pointing the wrong way and straining the bearing. Check your wheel bolts as well they do loosen off over time and cause problems.
| | #7 | ||
| Site Sub Admin | Re: bravo wheel bearing problem! If the garage supplied it then it should have a warrenty. Go back to the garage and they should fit a new one and the labour should be free. there is no way the bearing should go in a month. i have had my car 18 months and covered 30 thousand miles and the bearings are fine!
| | #8 | ||
| blessed are the apostates | Re: bravo wheel bearing problem! its possible they didnt use grease on the new bearing, or they used the wrong type of grease and it burnt off. | ||
| | sammiboo | Bravo / Brava | 255 | 28-02-2008 23:34 |
