manic_monkey
- Feb 12, 2007
- 25
- 7
Hi, Does anyone know how to set the cam timing after its been lost? I know there are markers to set piston one at TDC, but im not sure about how to get the cams right?
these tools lock the cams in the right position and can only go one way so with them installed the only thing you need to worry about is having the No.1 piston on firing TDCThanks. how would i use cam locking tools to rest the timing?
Ive already lost the timing (my mistake), and i dont trust the marks i put on the camshaft pulleys to reallign them correctly.
Are there any factory marks that should be on there and what do they look like?
