please can someone help me, i brought a fiat bravo 1.8 16v, started it up on the button, and drove it home, what i didnt know was that it had a small hole in the rad, which in turn cooked the head( hot), so the head came off and skimmed, replaced with a headset along with a water pump, thomostate, timing belt kit and alt belt, put it back together with the cam locking tool, and it took ages to start, so i changed the cam wheel and the cam sensor on that wheel, still the same, so i went on to change the tdc sensor on the back of the block(knock sensor and the rpm sensor on the flywheel, still the same, i did a compression test and 1 is low but now enough for it to not start, ive since had the injectors changed, the injector rail changed, the air flow meter, the pressure regulater, all 16 buckets, full service kit, and all sensors on the car changed??? still have a problem with it starting, once it dose start, the car runs fine with no smoke or loss of oil, secondly, there is a little hose from the injector rail to the manifold, if i turm it over there is no sucking from the pipe until it fires up, where it sucks quite strongly, if i get a mate to suck on the pipe then i start it, it starts first time??? if i leave the pipe off, the car drive ok, a bit choppy but ok, if i connect the pipe back, when i come to a sharp stop, the engine dies???? its been to my dealer, and the examiner shows no fault whatsoever, except key code, yet the code light gose out no problem,
regrads
ps, do anyone think the timing is out?????
