The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 10-02-2007   #1
rikmargetts's Avatar
Trader Rating: (0)
Reversing Lights
Hi All,
My Reversing lights on my Brava 1.6 100HSX don't work The bulbs appear to be ok, but from what I can gather the same fuse also works other lights... is this right? if it is then I don't think it is the fuse as only my reversing lights don't work. Any ideas?
Any help welcomed.
Rik
rikmargetts is offline
Old 11-02-2007   #2
What's the worst that can happen?
Dr_Pepper's Avatar
Trader Rating: (1)
Dr_Pepper has donated! United Kingdom
Re: Reversing Lights
Try the top left fuse of the 2 x 6 set in the fusebox. According to my sheet it is a 7.5 amp and works the reverse lights and the climate control - sounds wrong to me but might as well check if that fuse is ok.
If not I'd check the wires going into the light cluster with a voltmeter, that's easy enough but I guess the other thing that might go wrong is the switch attached to the gearbox somewhere, I've not looked where it is though
"The new rules are very simple. The FIA will keep them to themselves until such a time as Ferrari needs them" - Patrick Head
Dr_Pepper is offline
Old 12-02-2007   #3
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
on the gearbox there is a reverse light switch, which turns the reverse light on. check that its wire plug is connected securely, and it has power going to it. also try sticking a piece of wire between the contacts on the wiring plug to see if that switches the reverse light on (it should).
jug is offline
Reversing Lights pt108271 Ulysse 0 06-02-2007 16:14
(G) Reversing lights are not working on Sei? Its not the bulb. minidriver Cinquecento / Seicento 3 20-09-2006 18:17
Reversing and Front Fog lights do not work whoosh Coupe 2 18-08-2005 22:22
Reversing lights fenderman Ulysse 2 08-03-2004 21:54
instrument lights / reversing lights fenderman Ulysse 3 17-11-2003 22:25
