Same usual powerloss problem 1.8 hlx p-reg
hi all, not only have i popped a tyre and had to replace my cam today im now back with the usual power loss ive been reading about on here. Bassicly, it seems to move off fine in 1st with a bit more revs, then soon as you hit 2nd it kangeroo`s then sorts it self out, another thing when your going say 30 for a while in 4th.. it starts to loose all power so you need to drop down to 3rd with higher revs to keep moving. On idle the car seems to vibrate alot, like the dash and stuff, not as if its cutting out but not too far off... another thing ive relised, my cat started ratting about, and i think its becuase of this, if you look under the car when its running the exhuast seems to rattle loads which probably knocked my cat out so badly. The guy at my garage put my new cat on and said it will do for now but the engine`s faults may cause it to break again,..... anyway to put this long winded post to an end, tomorow i think im going to try adding some new plugs and leads even though it doesnt seem to be missfiring so much but its worth ago, and if that doesnt work ill probably start crying like the rest of you bravo owners with the same problem it seems. Just to add too, i had it hooked up to the computer at a more local garage and he said it showed up with no engine faults and said the usual try changing plugs possibly... i did sort of look at one plug and it looked shiney, but im no mechanic so looking at a spark plg probably doesnt tell you much. anyway anyone know is scrappys are open on sundays? or where i can get some leads and plugs from. any advice would be appreciated as me and a few mates where hoping to go to inverness init on wednesday and i have a bad feeling about it ;/ cheers
