the relay is next thing to try. i'm not sure if the relay was on the main fusebox, or on the wiper motor. haynes will tell you. i havent got mine handy at the minute.
you can pass an MOT even with the airbag light remaining on, an airbag has nothing to do with your MOT. it has probably come on because you had the key in the ignition while you were removing the stalk assembly. fiat can reset it to turn it off, costing approx £65.
pull the LED out, you cant reset the airbag ecu without a fiat/alfa examiner smart machine. most 3rd party tools cant access the airbag module, although you could try asking about to see if anyone else can do it for cheaper. make sure they agree it is free if they cant do it, most places charge for their time, not for a successful diagnosis.
